10R80 Issue Transmission
BAKER
New york
Baker
Mustang 2019 roush RS3
Hello Guys,
I have a Roush 2019 AT 22,000km, after driving around 20min i feel like the transmission start "trembling shaking" a bit while the car down shift from 6 to 5 gear.
But on snow/wet mode or below 20min ( transmission low tem )drive everything seems smooth to normal.
Any idea to slove this issue went to ford they says nothing found gear box normal.
Go here, Post #1, scroll down in it until you hit the link for 10R80 TSB/SSM’s. Read through the TSB/SSM’s and see if anything is similar to your issue. It could be clutch pack related, valve body or even driveshaft issues. Hard to say without being able to be with the car. Check driveshaft center support bearing and the bolts to both front and rear flanges.
https://www.mustang6g.com/forums/th...tions-to-harsh-or-no-shift-conditions.135463/
BAKER
BAKER
New york
Baker
Hello Guys,
Dear CJ,
thank you very much for your time bro, as you told me to check the driveshaft i notice one things When I pushed the gas pedal hard in a drag I heard something like shaking under the hand break compartment, i will tell ford to check the driveshaft.
thx again
