nastang87xx
- Jun 5, 2015
- San Diego, CA
- 2016 GT350 Track Pack
Season is starting up and SCCA will be in full tilt for the whole country in about 6 weeks. After doing a hard fought season last year, here seems to be nominal LEGAL setups for appropriate classes (note that the R is SS class due to tires and no back seats):
A-Street
CAM-C (light setup)
CAM-C (heavy setup)
Modified
Do NOT upgrade power or dial back your tune to a street related or milder tune. When you're coming out of corners, you often end up right in the meat of the torque shift around that 3200 - 4000 RPM range. It's hard to modulate and the last thing you need is more power for course running (on autocross, track is a different story).
Do NOT touch the rear sway bar except for the end links when legal. Remember autocross surfaces are rather imperfect and too much stiffness can throw you off.
For you Track Pack, R, and '17+ guys, run in Sport mode, all nannies off. Track is too stiff.
Happy hunting. You're still gonna lose to an S2000 after index... :doh:
A-Street
- Adjustable front swaybar at full stiff
- Upgraded front endlinks
- Bridgestone RE71R 305/30-19 square (just do it, 10.5 vs 11 makes zero difference on small courses, trust me)
CAM-C (light setup)
- A-Street
- Caster camber plates, punch everything full out as much as you can
- 19 x 11 wheels square
- Upgraded vertical links
- Rear alignment kit
CAM-C (heavy setup)
- CAM-C (light setup)
- Rear cradle lockout kit
- Bump steer correction kit
Modified
- CAM-C (heavy setup)
- Rear seat delete
- 19 x 11 wheels front, 19 x 12 wheels rear
- Hoosier A7 315/30-19 front, 325/30-19 rear
- GT350R wing or equivalent, not to exceed 8 sq ft surface area
- GT350R front splitter
- Heavy duty brake pads of your choice
