2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com 21 - AmericanMuscle - 2
Homepage Wiki MOTM Register Search Today's Posts Mark Forums Read Ford Bronco Forum Calendar Garage
Go Back   2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com > 2015+ Ford Mustang Forum > Shelby GT350 Mustang
Shelby GT350 Mustang Discussions of the 2015+ Shelby GT350 and GT350R Mustang
User Tag List
Reply
Thread Tools Search this Thread Display Modes
Old 02-10-2017, 12:48 AM   #1
kart125
kart125's Avatar
Drives: 2017 GT350/2008 Saab TurboX SC
Thanked: 108 Times in 69 Posts
iTrader Score: 1 reviews
Question about R springs
I'm looking to upgrade my Gt350 springs to R springs. I found on the general forums a spreadsheet with all the spring rates from stock to aftermaket springs.
They rate GT350 F/R to 194/914 and GT350R to 240/914.
Is there a benefit in going for the rear R springs since the spring rate is the same as the non-R?
kart125 is offline   Reply With Quote
Old 02-10-2017, 12:52 AM   #2
zzj
zzj's Avatar
Drives: 2017 GT350 H1828
Thanked: 77 Times in 40 Posts
iTrader Score: 0 reviews
I think the R springs are a little bit lower regardless spring rate. You don't want lower front springs with higher non-R rear springs. They do have different part numbers for rear springs so there must be a reason for that since they have the same rate.
zzj is offline   Reply With Quote
Users thanking this:
Old 02-10-2017, 01:04 AM   #3
kart125
kart125's Avatar
I've read in other threads confusing info about R springs lowering the car or not... Voodooo confirmed it does not lower the car and he knows his stuff. I agree that if different p/n there must be a reason...
Old 02-10-2017, 01:10 AM   #4
Voodooo
Drives: Carroll Shelbys Soul Lives Under My GT350 Hood
Thanked: 2,394 Times in 1,548 Posts
The R springs are the way to go. Unless you want to lower the car. The R springs will lower the car 0 to 1/4". For how cheap the springs cost, I bought all 4 and powdered coated mine red so I knew for personal reference which springs I had on the car and wouldn't confuse them with the stock Non-R springs.
Voodooo is offline   Reply With Quote
Old 02-10-2017, 01:15 AM   #5
zzj
zzj's Avatar
I remember that post since I was wondering the same when I ordering the springs myself. I research a lot of online info and getting the answers from lowering 0, 1/8 and 1/4 inch. So it's not a very noticeable drop if they are lowered at all. Voodoo had both front and rear on his car. I end up got all of them. Rear pair cost about 200 or so if I remember it right. So I think I'd rather spend a little bit more to make myself worry free from lowering issue.
Old 02-10-2017, 01:35 AM   #6
Voodooo
Quote:
You paid $200 for just the rear springs?
Old 02-10-2017, 01:46 AM   #7
zzj
zzj's Avatar
Quote:
Looks like I got wrong memory! Just checked again and I spend 250ish for all springs and 60ish for the rear stabilizer bar
Old 02-10-2017, 06:58 PM   #8
RoadRacer
RoadRacer's Avatar
Drives: 2016 GT350
Thanked: 86 Times in 51 Posts
What about magneride recalibration to match the higher spring rates?
RoadRacer is offline   Reply With Quote
Old 02-10-2017, 07:08 PM   #9
Voodooo
Quote:
Not needed.
Old 02-10-2017, 07:11 PM   #10
RoadRacer
RoadRacer's Avatar
Drives: 2016 GT350
Any other expert opinions?
Old 02-10-2017, 07:23 PM   #11
Voodooo
Lol. Ok. I'm not the only one who's swapped to R springs.
But I am one of the first and you do not need to do anything else.
Old 02-10-2017, 07:34 PM   #12
RoadRacer
RoadRacer's Avatar
Drives: 2016 GT350
Seems a little odd that increasing the front rates that much wouldn't require a recalibration of the magneride dampers. Is your opinion based on experience with your cars performance or validated by someone with understanding of the programming running our dampers?
Old 02-10-2017, 07:51 PM   #13
Voodooo
Thats ok. Don't take my word. Others have done it also.
DSC, vorshlag, cortex etc.
you asked and I answered your question. Plain and simple. If you want to run R springs you do not need a recalibration. But I'm also going to use a DSC controller to further enhance my cars performance.
If you notice my mods below I also replaced all the bushings with bearings, reduced weight with forgeline wheels, pilot sport cup 2 305/30 tires, replaced all the rubber chassis bushings with solid bushings, Vorshlag camber plates etc.
Old 02-10-2017, 08:14 PM   #14
Bingo13
Bingo13's Avatar
Drives: 2016 GT350 TP, 2003 SVT Cobra, 2000 Cobra R
Thanked: 54 Times in 25 Posts
The re-calibration is not needed. This is based on (7) track events with the R-springs installed and with a Ford Engineer attending an early event at TWS.
Bingo13 is offline   Reply With Quote
Old 02-10-2017, 08:32 PM   #15
65sohc
Drives: 2016 GT350
Thanked: 178 Times in 112 Posts
The Magneride shocks are the same ones used on the Corvette. Corvettes and Mustangs also use the same DSC controller to tune the damping. All Corvettes use same DSC calibration, regardless of spring. In fact the calibration values for the Shelby are identical to those of the Corvette. Michael Levitas has been daily driving an R for the past two weeks and will be releasing updated software and firmware next week. I mentioned to him that my car is bouncy on certain roads. He told me to be sure the "transport blocks" are out from the springs. Has anyone heard of those?
__________________
2016 GT350: black, Tech pack, JLT CAI and catch can. Lund Flex Fuel tune, DSC Magnetuner
65sohc is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Lowering Springs Question RoushStang Suspension, Brakes & Chassis 45 07-15-2016 05:12 PM
Lowering Springs question CompOrange_GT Suspension, Brakes & Chassis 0 04-10-2016 11:00 AM
Eibach Springs installation question iljalop I4 2.3L EcoBoost Engine / Mods: Bolt-ons, Exhaust, Tuning 3 09-01-2015 09:44 AM
Question for those who installed their own springs BackinBlackS550 Suspension, Brakes & Chassis 4 01-16-2015 03:20 PM
quick question about PP springs vs base springs Heinoceros Suspension, Brakes & Chassis 8 12-11-2014 01:50 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.2.4 (Lite) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.Navbar with Avatar by Motorradforum
Garage vBulletin Plugins by Drive Thru Online, Inc.
