SEE MUSTANG6G WIKI FOR MORE DETAILS
Engines/Trims
Dimensions
Chassis
Transmissions
Suspension
Brakes
Performance Packages
2015 Mustang EcoBoost:
Technology
Interior
Convertible
2015 Mustang colors
SPECS CHARTS and DIAGRAMS
Dimensions Comparison (compiled by JohnnyBlack)
Engines/Trims
- 5.0L V8 (Coyote)
- 435 HP @ 6500 RPM
- 400 LB-FT (on 93 octane)
- 87 HP/LITER
- 7000 RPM redline
- 3,705 lbs curb weight (manual)
- 3,729 lbs curb weight (automatic)
- 53/47 weight distribution
- 8.52 pounds per horsepower
- 155 MPH top speed
- Sintered-iron forged Boss-like 302 rods and springs
- Upgrade valvetrain and cylinder heads with improved port design
- Larger valves and cams
- New intake manifold with charge motion-control valves
- Redesigned piston tops
- Balanced forged crank
- 11:1 compression ratio
- Even more detailed changes:
- New cams with 1mm more intake lift and 2mm more lift on the exhaust side
- New cylinder heads with revised high-flow ports and slightly larger valves
- Mid-lock cam phasers to provide greater range of cam timing on the intake side
- A revised intake manifold with charge-motion control valves.
- The forged connecting rods from the current Boss 302 engine
- The forged balanced crank from the current Boss 302 engine
- The valve springs from the current Boss 302 engine
- Standard oil cooler
- 3.7L V6
- 300 HP
- 280 LB-FT (on 93 octane)
- 81 HP/LITER
- 3,526 lbs curb weight (manual)
- 3,530 lbs curb weight (automatic)
- 10.5:1 compression ratio
- 2.3L inline 4 Cylinder EcoBoost
- 310 HP
- 320 LB-FT (on 93 octane)
- 135 HP/LITER (highest of any Ford production car, ever)
- 3,532 lbs curb weight (manual)
- 3,524 curb weight (automatic)
- 52/48 weight distribution
- 11.37 pounds per horsepower
- Twin-scroll turbocharger
- Direct injection
- Twin independent variable cam timing
- Steel crank
- 3-port cylinder
- Forged steel crankshaft
- Forged steel connecting rods
- High-pressure die-cast aluminum cylinder block
- Oversquared (87.5 x 94)
- Mahle pistons
- 5 bearing crank
- Sodium-filled exhaust valves
- Steel ring carriers
- Composite cam cover
Dimensions
- 0.12 in (3mm) longer
- 0.51 in (13mm) wider than outgoing 2014 Mustang (s197)
- 1.49 in (38mm) lower roof
- 0.78 in (20mm) lower seating position
Chassis
- 28% more torsional stiffness (fastback)
- 15% more torsional stiffness (convertible)
- Lower cowl uses DP 800 Steel
- A Pillar/Roof uses a single hydroformed DP 1000 high-strength steel
- B Pillar uses Boron Steel
- Body is 25 LBS lighter than the 2014
Transmissions
- Updated manual gearbox (Getrag 6-speed)
- revised shift linkage for shorter throws / smooth shifting
- Automatic with paddle shifters (SelectShift 6-speed)
- rev matching
- redesigned case with lighter internals
Suspension
- All-new front and rear suspension systems.
- New perimeter front subframe helps stiffen the structure while reducing mass, providing a better foundation for more predictable wheel control that benefits handling, steering and ride
- New suspension geometry now generates twice as much anti-squat and anti-lift force for better pitch control
- Front MacPherson strut system with new double-ball-joint spindle (allows for larger brakes and improved handling feedback)
- Rear integral-link independent rear suspension (benchmarked against Boss 302)
- New aluminum rear knuckles help reduce unsprung mass for improved ride and handling
Brakes
- Three available brake packages
- V6 Mustang / Standard Mustang EcoBoost:
- 2-piston, 43-millimeter floating calipers, 320- millimeter rotors, front; single-piston, 45-millimeter calipers, 320-millimeter rotors, rear
- Mustang EcoBoost Performance Pack / Standard Mustang GT:
- 4-piston, 46-millimeter fixed calipers, 352-millimeter rotors, front; single-piston, 45-millimeter calipers, 330-millimeter rotors, rear (equivalent to 2014 Mustang GT track package)
- Mustang GT Performance Pack:
- 6-piston, 36-millimeter Brembo™ calipers, 380-millimeter rotors, front; single-piston, 45-millimeter calipers, 330-millimeter rotors, rear (same package found on 2014 Shelby GT500)
- Front brakes: Four-piston, 46-millimeter fixed aluminum calipers with 352-millimeter rotors
- Rear brakes: Single-piston, 45-millimeter floating iron calipers with 330-millimeter rotors
- Unique 19x9-inch alloy wheels painted Ebony Black with Pirelli 255/40R19 Y-speed-rated tires front and rear
- 3.55:1 final drive ratio
- Retuned springs, bushings and monotube rear dampers
- Additional cooling capability for track-day durability
- Thicker rear sway bar
- K-brace connecting strut towers to bulkhead
- Unique tuning for ABS, electronic stability control and electric power-assisted steering
- Center gauge pack
- Front brakes: Brembo six-piston, 36-millimeter fixed aluminum calipers with 380-millimeter rotors
- Unique 19x9-inch Ebony Black painted alloy wheels with Pirelli 255/40R19 Y-speed-rated tires, front; 19x9.5-inch alloy wheels with Pirelli 275/40R19 Y-speed-rated tires, rear
- Strut tower brace
- 3.73:1 final drive ratio with Torsen differential
- Unique front splitter to channel cooling air to the front brakes
- Center gauge pack
Technology
- Launch Control (GT model)
- Selectable Drive Modes - Console switches to quickly adjust steering effort, engine response, and transmission and electronic stability control settings
- Normal mode
- Sport mode
- Track mode
- Snow mode
- Intelligent Access with push-button start to SYNC® and MyKey®
- Available Track Apps (standard on GT, optional on EcoBoost model)
- MyColor gauges and
- new Shaker Pro audio system
- Blind Spot Information System (BLIS) with cross-traffic alert
- Adaptive cruise control
- SYNC AppLink
- Oil pressure and vacuum/boost gauges
- Push-button start
- Tire pressure monitoring system (TPMS)
- Remote starting and remote window opening options
Interior
- Occupants lowered 0.78in (20mm)
- More overall interior room
- Visibility improved
- More trunk space
- Rear seat pass-through 40mm wider
- Rear seats feature more hip and shoulder room
- USB and 12V outlets
Convertible
- Cloth top and center latch.
- Top opens and closes in 7 seconds (half the time of the outgoing model)
2015 Mustang colors
- Competition Orange
- Triple Yellow
- Oxford White
- Deep Impact Blue
- Ruby Red
- Race Red
- Ingot Silver
- Magnetic
- Guard
- Black
- Kona Blue (50 Years Limited Edition Only)
- Wimbledon White (50 Years Limited Edition Only)
