info@trinityautosport
- Feb 3, 2016
- Anaheim, CA
- 2015 Mustang
We have seen that many have not heard of Swift springs, mainly due to the fact that they are known for imports and this is the first year that they make springs for the Mustang. We would like to give more information and details on Swift springs.
The Spec-R springs are a very performance oriented linear lowering spring. During the development of these springs available stroke was tested as well as the geometries of the chassis to figure out the drop. Swift Spec-R springs are designed at the upper limits of the OEM shock valving. They are track tested and tuned for optimum performance, yet comfortable enough for a daily driver.
SPECIFICATIONS; RATE in LBS, DROP in INCHES
| TYPE ...... | F RATE. | R RATE. | F DROP | R DROP |
| Linear .... | 279 ... | 782 ... | 1.1... | 1.0... |
We have personally have experienced a great reduction in body roll, reduced nose-dive, and improved handling. We are confident that previous and current Swift owners can attest to the quality and performance of these springs.
Track time of our Mustang with and without swift springs at the track.
http://www.mustang6g.com/forums/showthread.php?t=35500&page=2
Pictures of our Mustang at the track:
Shop Mustang with Swift springs.
Swift Springs was founded in 1997 in Tokyo Japan as a motor sports division of Tokyo Hatsujo Manufacturing Co, Ltd. that has been leading the spring industry since 1924. Since the formation of Swift, it has been lead by the former racer and suspension expert, Kei Yokota, and the chief engineer, Yasu Saito. Swift has made a name for itself on the tracks of Asia, Europe, and U.S. by defying all accepted concepts and speculations about the future, if any, in coil spring science.
All Springs are not created equal, the diameters and spring rates can be similar, but the process of manufacturing springs plays a huge factor in how they will perform. Through extensive knowledge in performance springs, Swift has perfected the process of manufacturing springs. When many other companies were looking at expensive and brittle titanium composites to create the next evolution of springs, Swift was looking at reinventing the entire science of coil spring dynamics. Swift's R & D team created material, called H5S.TW, which is stronger then regular silicon chrome material. Because of this material, Swift has been able to make spring wire thinner, and could wind the springs with fewer coils, which greatly decreases weight while dramatically increasing available stroke.
