GT350 owner's supplement
Patio208
GT350 Member
Chicago
Patrick
2020 GT 500 #L2287
Nice!
Honus
Southern Tier, NY
2016 RR GT350 Tech
You're a scholar and a gentleman.
The break in period isn't too different from the Boss302.
Honus
Southern Tier, NY
2016 RR GT350 Tech
This should also put the kibosh on that whole "over-rev" debacle. Not at all mentioned in the supplement, which is exactly where it would be if it were a real thing.
F1-R
Norfolk, VA (Navy)
Aliek "D12"
16' GT350 AG Track P. w/ blk OTT stripes/b. roof
Very good information, I can really see myself owning this car. Question: I will probably get the base model due to budget and the fact that I can't justify the extra performance, based on the more experienced drivers here personal experience, at which point will I really be hating the fact that I don't have Magneride, extra coolers, and brace bar? Thank you.
Guardstang
Hamilton, Ont
Shawn
2015 Ecoboost
You just know lawyers co-write that stuff--check out the warning not to have peaple sit in the back of seat delete cars and how to tether a kids seat without a back seat.
Hack
Minneapolis
Mustang, Challenger
disneyfun1
Phoenix, AZ
Art
2020 GT Prem Calif Special, 2021 Mustang Mach-E
SidewaysMike
Somehwhere in the Med
2016 GT PP
Transmission Fluid
This may sound dumb but did I read correctly that the GT350 uses "Motorcraft Mercon LV Automatic Transmission Fluid" for its manual transmission?
Is it normal for manuals to use automatic transmission fluid?
S550guy
MI
Mustang
Yes, it is normal. Since ATF is more commonly found in stores, many manufacturers are/have been using that fluid in their transmissions (both auto and manual).
My '02 GT calls for Motorcraft ATF, and that is a manual as well.
JWS
Dunnellon, Florida
James
2015 WW-50th LE Auto-0745-Grandé
DIGITAL SPEEDOMETER!
OK, now let's update our regular Mustangs to Display this!
65Terdlingua
Kansas City
1965 Mustang
Not really because ATF is more commonly found in stores. You can find gear oil just as easily, but since about 20+ years ago most manuals have used ATF because that's what is recommended for the tighter and more precise bearings and bushings that are used now. It is also a better lubricant for the gears.
IGJoe2192
Federal Way
Automobile
Only thing I found was this.
"*Redline is limited to 8000 RPM until the engine oil temperature exceeds 190°F (88°C)"
garagelogic
TN
1990 LX 5.0 Coupe-Coyote Swapped
Own or LEASE? Are they offering a lease on the GT350?
