It really wasn't a track alignment, more a general performance alignment. The specs follow:GFD, sir, GFD. :cheers:
You did a track alignment on the car; how was it handling for you before this?
Nice to know.It really wasn't a track alignment, more a general performance alignment. The specs follow:
Front Camber: -1.7 degrees
Rear Camber: -1.0 degrees
Front toe: +0.04 degrees
Rear toe: +0.03 degrees
Front caster: +7.5 degrees
Aside from making the toe a bit closer to zero, the only thing we did is take the rear camber from -2.0 degrees to -1.0 degrees. This can be done with the factory suspension and a skilled and willing tech (guy said it was a pain in the ass but he was determined to make it right).
Before this alignment, the car had some understeer at the limit which makes since with the greater rear camber than front. A $100 alignment job solved all that.
Enjoy that pony, man, she's a beaut.
Yep SCCA track night. Great event run very professionally and with a focus on getting people as much track time as possible.Nice.
Suggest a first step be better pads (Carbotech XP's if they're available yet) and better fluid (Motul RBF600). Wider wheels to go with better tires - even the PP's 9.5" wide rear wheels aren't any too big.
Was this an SCCA Track night?
Norm
nice vid notblake. could i ask the speeds you were doing . on the big track it looks slow but by the tire sounds i know its not. thanks, tomHad my first track day (period) in the 2015 Mustang GT and I couldn't have been more surprised with how well this car handled itself.
Check it out:
Haha didn't have much time to look down. I think the fastest i hit on the straight was about 100mph. And carrying about 80mph through the 14-15 section.nice vid notblake. could i ask the speeds you were doing . on the big track it looks slow but by the tire sounds i know its not. thanks, tom
