Blowfish Transmission Bracket**Best Mod
Fisticuffs
Miami
Anthony
2015 Mustang GT PP Tri Coat Yellow
I kept on having shift crunch every so often and gave me this vague feel.
Once I installed the bracket the shifts are as crisp as you could want.
I compare it to closing the bolt on a rifle, just very precise and deliberate and you never miss your shift.
I see all these people taking springs off the clutch and all these other tricks but this thing is amazing.
A bit of a beotch to install but if you install it at the same time you put in your cat back it's easy.
I have pics is anyone is interested but go on YouTube and cj pony parts has a great review and install vid.
Super Werty
AZ
2015 PP GT
So I'm still trying to figure all of this out. Basically this stiffens up the stock shifter correct?
So my question is, can it be used with an aftermarket shifter like the one from Barton?
Can it be used with a poly trans mount?
Can all 3 be used together for a super tight package?
rio16
MAD_50HH
Bay Area SJ, CA
Rio
2015 Mustang GT Whippled Competition Orange
No you cannot use it w barton
Fisticuffs
Fisticuffs
Miami
Anthony
If you ever are in Miami send me a message and I'll let you try it out. It's one of those things that you have to experience to understand.
Grimace427
NoVA
2011 Mustang 5.0
Here are more details on the bracket. It firmly bolts the shifter to the transmission as a solid unit instead of the factory body-mounted remote shifter.
http://www.mustang6g.com/forums/showthread.php?t=12280&highlight=blowfish
The factory method mounts the shifter to the body to reduce noise and vibration, but this can cause excessive movement between the shifter and transmission causing funky shifting. Mounting the shifter to the transmission gives you a solid setup where missing a shift will be entirely driver error.
yellowragtop
Dallas, TX
2001 mustang conv
THIS BRACKET probably IS INDEED the best MOD
I just watched the video and saw this bracket. I am in awe that someone took the time to try to make a nice sturdy structure for the shifter.
GreenWolfGT
San Jose, CA
2015 Guard GT Premium Manual
How's the NVH? I'm very interested but definitely don't want to add any annoyances inside?
Magnetic
Michigan
Sam
Magnetic GT pp
after hitting the track yesterday i have to do this mod or a Barton/ MGW. This car makes me feel like it is my first stick shift vehicle. I really can't believe how hard it is to hit 3rd gear when up in the RPM's.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
The steeda trans bushing definitely helps with this.
embraceentropy
Georgia, USA
2019 GT350
Will this have an effect on the transmission warranty?
