steph93lx
- Sep 30, 2014
- Montreal area
- 2018 GT 301A A10, Modded N/A 1993 coupe 5.0L
Here is the M6G Official S550 Mustang 1/4 Mile Fast List & Leaderboards (V8)
Time to hit the track and post up your 1/4 mile times!
1. Post the details of your quarter-mile pass . You can post just a pick of your time slip showing all the slip with date and track name. Please list ALL your modifications. If you have remove seats, have a smaller battery or have other weight reduction please put it in your modifications list. Fill in this template and cut/paste it into your post.
Use the modification codes and fast list categories at the bottom of this post.
Vehicle, Trim, DRAG MODE USE Y/N & Options:
Modifications (if any):
Fast List Category Submitted For:
R/T.........................................
60'..........................................
330'........................................
660'........................................
660’ mph.................................
1000'......................................
1320'......................................
1320’ mph….............................
race weight w/driver:
Name of the track:
Date of pass:
Weather conditions: (include the Density Altitude):
You can use this DA CALCULATOR
2. Upload an image of your time slip directly onto Mustang6G and not a third-party photo service (to ensure the images are never lost).
The full time slip must include the date/time of your pass and identify the track that issued the slip.
3. Track times will not be corrected for weather or track altitude.
Those elements can be noted in the comment portion of the submission to clarify the conditions in which the run was made.
4. If two members submit an identical 1320’ ET to the thousandths of a second, the tiebreaker is the higher 1320’ mph.
5. Only one pass per member per categorie except if you have both a timeslip for the 2015-2017 and a 2018+. In that case you can have 2 pass, one for each years span. I will not erase any 2015-2017 times. Later with more 2018+ timeslip added more list will be created.
Modification Code:
Vehicle, Trim & Transmission: 2015 Mustang GT PP, Manual
Modifications (if any): CAI, Tune, Exhaust
Fast List Category Submitted For: #3 (BOLT-ONS WITHOUT INTERNAL ENGINE MODIFICATIONS)
R/T......................................... .412
60'.......................................... 1.935
330'........................................ 5.470
660'........................................ 8.292
660’ mph................................. 89.06
1000'......................................10.698
1320'...................................... 12.693
1320’ mph…............................. 113.78
Name of the track: Milan Dragway
Date of pass: 1/1/2015
Weather conditions: (Density Altitude, if known): 58 DA -350
IF YOU NOTICE ANY MISTAKES OR TYPOS PLEASE PM ME. DO NOT MAKE AN UPDATE REQUEST IN THE THREAD! WE'D LIKE TO KEEP THE LIST AS CLEAN AS POSSIBLE. THANKS FOR YOUR COOPERATION!
- We will be compiling a 1/4 Mile Leaderboard showing the fastest times achieved by members in each of the 3 categories below.
- All of the rules below need to be followed or your time will not be included.
- This thread is for posting 1/4 mile times and time slips ONLY. Let's save the discussions for other threads.
Name of the track:
Date of pass:
Modification Code:
- Heads - Aftermarket Heads or Ported Factory Heads
- CAI - Cold Air Intake
- Intake manifold -Cobra jet, Boss, Gt350, 2018 Gt for the pre 2018 etc.
- Exh. - Exhaust mods of any kind (muffler delete, axleback, catbacks, x-pipe, etc)
- PTB - Ported Throttle Body
- PI - Ported Intake
- LT - Long Tube Headers
- UDP - Under Drive Pulley
- Shorties - Short Length Headers
- Gears - Non Factory Gears
- DR - Street Legal Drag Racing Tires
- SK - Skinnies smaller front tires and wheels
- SL - Slicks racing Drag Tires (non street legal tires)
- D/P - Dragpack Tires package (skinnies front+ drag radial or slick rear)
- Tune - Non Factory Tuning
- WR - Weight Reduction-Please list ALL weight reduction with the time slip.
- SC - Supercharged
- Turbo - Turbocharged
- Nitrous - Nitrous
- DS-Aluminum or carbon fiber drive shaft.
- 2 Step-2 Step launch control
- Tr.Brake- Trans. Brake
- CONV-High stall torque converter
- STOCK ON STOCK TIRES or aftermarket wheel and STREET TIRE: 100% factory stock with no performance mods whatsoever (Must have STREET radial tires, stock exhaust, stock airpath, stock/untuned computer (ECU/PCM) etc.).
- BOLT-ONS WITHOUT INTERNAL ENGINE MODIFICATIONS: (e.g. exhaust, modified airpath, headers, PCM-tune, aftermarket clutch, non-stock rear gears, Drag radials,skinny front tires. High stall converter
- POWER ADDERS, FORCED INDUCTION AND/OR INTERNAL ENGINE MODIFICATIONS(i.e. nitrous, turbo, supercharger, increased displacement. Heads, Cams.
CURRENT LEADERBOARDS (UPDATED 07-21-2018)
