1/4 Mile Fast List 2.0
Coyote Chase
Don
2010/2018 Mustang
My 2018 A10 base stock Ecoboost ran a 13.23 on a 62° day at Cecil County, MD, 341' elevation. It's completely stock, but I did adjust the tire pressures.
That's an excellent bone stock ET!
What rear gear is your Mustang equipped?
Coyote Chase
Don
2010/2018 Mustang
That's the same gear I have in my Mustang! I switched to 26" tall wheels and tires (275/40R17 tire & 17x10 wheel), which helps my launch, 60', etc.
But my goal is to change my rearend gear and use a taller tire.
jdsfly
Wilmington, DE
2018 Mustang Ecoboost, A10
Yup, I know you from the other forum.
The gear and tire change might work for you, but it's probably small gains for you, for the money.
18GTSC
Las Vegas Nevada
Darin
2018 Mustang GT Roush SC, 2017 Raptor, 89 Wide Fox
2018, PP1, DRAG MODE USE Y
A10
3.55 gears
2nd gear burnout
Left it in Drive...left just off idle.
Modifications:
Palm Beach Dyno Tuned E85
Roush 2650 SuperCharger with Phase2 cooler
X85 (VP - E85)
Sai Li dual pumps ( drops to 49psi at 6800 on X85 )
Sai Li Rails
id1050x injectors
Stainless Works Headers with high flow cats
SR X-pipe with stock non-active exhaust
Gforce 1500hp Axles
DSS Aluminum Driveshaft
Stifflers Loop
Whiteline vertical links
Whiteline Diff Bushings
BMR IRS Stiff kit
Eibach PRO-KIT springs
Drag pack VMS wheels
MT ET R tires NEW (defective flat spots going back for RMA)
MT Front runners
Removed Passenger seat and Rear seat
0 rear camber for the Drags
R/T 0.785
60' 1.716
330' 4.605
660' 6.919
660’ 107.73 mph
1000' 8.882
1320' 10.536
1320’ 138.13 mph
race weight w/driver: 4082
Name of the track: LVMS 2028 feet
Date of pass: 12/10/2021
Weather conditions: 51 degrees (felt way cooler) with a direct headwind flags were solid
Density Altitude: 1747 feet
Relative Density: 94.99 %
1st and only complete run in this car ever.
2nd run the tires were so out of round and bouncing at half track so I lifted and parked it.
21 antimatter
Pennsylvania
David
2021 Antimatter Blue GT Premium
New 2021 GT Premium Antimatter Blue. Just over 1,000 miles. full tank of 87 Octane, 401A, 10AT, AE, B&O, Digital Gauges, 3.15s, 18" wheels with stock P Zero Neros at 33psi. Driver ~250#, luggage ~100#. DA at time of run was ~1,443 feet. March 19th at Cecil County Dragway. No burnout. Drag Strip Mode, TC on for safety (first time at Cecil in ~7 1/2 years), 1,500 rpm brake launch, paddle shifted in manual mode at ~7,500 rpm. TC intervention on launch, 1-2 shift, 2-3 shift. As I mod the car, I plan to post slips. Long term goals are to go from stock to 9.0 by the time I hit retirement age.
21 antimatter
Pennsylvania
David
First time at track with the new car and wanted worst possible conditions for baseline runs. Full tank, extra weight, full air pressure, heat soaked, etc.
Djetok
Oklahoma
Lance
19 GT PP1
19 gt pp1 A10 3.55 vmp tune 93, lth, Cai , ford racing x pipe, borla s type. Nitto nt555 305 rears are 32 psi
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
New England Dragway 9/3/2022
10:42am
2016 GT Premium
4010lb race weight
A6/3.15 gear
700 DA
Gen3R, 17psi, E78, 305/45/17 M/T SS’s, front skinnies
gimmie11s
SoCal
Murica!
10:42am
2016 GT Premium
4010lb race weight
A6/3.15 gear
700 DA
Mid 9's, 145 mph, air conditioning, leather, premium sound.
What's not to like? Beast mode right here.
Congrats.
wazslow
PA
2016 Mustang GT/CS
10:42am
2016 GT Premium
4010lb race weight
A6/3.15 gear
700 DA
Nice run, congrats! How are you leaving? Off idle/footbrake/transbrake?
Cory S
Bradford, NH
Cory
