Tank
9/11 - Never Forget
- Feb 19, 2016
- Above the Notches
- G0853
So it took awhile but I was able to check the As-Built data for my Tech and compare it to the VIN Matt provided. For what it's worth, this is what I came up with.Just as an FYI for you folks- I will, time permitting, compare the PCM as-built data for my Tech with the VIN [MENTION=18007]mattlqx[/MENTION] provided for the Track.
I'm hoping to keep it 'simple' and not get into the four way comparison as described above..
My goal will be to identify changes in addresses that might help pinpoint the fields where the differential data/controls are.
From the top, the two different VINS had different:
"Tear Tags" - Tech was TRS7 & Track was SBH6
"Vehicle Data" - Tech was 16F0 FFFF FF03 & Track was 16F2 FFFF FF05
Of the nine PCM Modules listed for both, the only difference was PCM 4:
Tech was FFFF 2F14 2176 & Track was FFFF 2F12 2174
All other data was grouped under the general heading of "BCE Modules". I copied all addresses and instructions into Microsoft Excel spreadsheets and compared the Tech to the Track and the Track to the Tech. I weeded out similar addresses and values and compiled the same addresses with different values on the spreadsheet posted below. I also compiled different addresses for the Tech and Track and a couple of similar addresses with the same instructions for known values. I put known functions, from the Forscan document, on the right of the appropriate addresses.
I hope this might be helpful...:cheers:
