- Nov 2, 2015
- SE Michigan
- Scott
- Carroll Shelbys Soul Lives Under My GT350 Hood
- Banned
- #46
Lol anything for the family.Good work Voodoo!
Hey [MENTION=19066]Epiphany[/MENTION],A gentleman I know has already cracked a few of these. I'll ask and see if he'll look at this one.
That's great Epiphany! CongratulationsMost recently? Jesse at OEMRadio can remotely do certain module changes, such as enabling the exhaust toggle when I upgraded to an 8" screen/dash bezel with toggle switches.
I haven't had a chance to check my car yet, but I think your first point is correct. The Tech Pack main harness won't support the Track Pack rear harnesses. However, the exhaust control and shock control is all back there in the Tech Pack, so _soemthing_ is back there.If you can't find a spot where the new 8 pin connector attaches to the body floor wiring harness, I think you just found out there's a different main wiring loom.
In fact, fordparts breaks out the body floor wiring harness for the base, tech, track. Looks like 4 different skus, including 2017. Those harnesses trend for ~$500, and you still probably have to enable the logic in the BCM.
Unless you have to maintain a stock racing class, this cost seems too high for a PWM pump that wouldn't be too hard to wire up to an external circuit. Or just use an external pump entirely - people have posted some nice ones.
Then there's still the differential temp sensor.
I'll see about scanning them when I get home tonight, without breaking copyright laws. Honestly, there's only one page needed, and three connectors that can help. There are two ways to get it - the Helms CD has them, and there's also a hard copy of the wiring diagrams available.I haven't had a chance to check my car yet, but I think your first point is correct. The Tech Pack main harness won't support the Track Pack rear harnesses. However, the exhaust control and shock control is all back there in the Tech Pack, so _soemthing_ is back there.
I'll find out this weekend.
I'd like to thank Scott (voodoo) for going out of the way to supply pictures and numbers from his Track Pack car. That has helped immensely.
Some questions, since I don't have the wiring diagrams.... Where can we find the wiring diagrams? I did order the Helm manual. Not arrived yet.
1) Will the 2017 main harness support the Tech Pack, the GT seats, etc?
Yes, it'd be expensive and time consuming to buy it and change it out if so it's not that economic, anyway.
And yes, some programming would probably be required.
2) Is there any indication of the Tech Pack harness supporting the diff temp sensor? i.e., is there an 'extra wire' that runs to the correct pin on the controller?
I'm guessing not... I'd really like to have the display show the Axle Temp.
3) Does anyone know the power requirement for the diff pump?
i.e., what's the max current/amps it requires?
My fall back to all this, if the Tech Pack will not support the Track Pack pigtails in the back, is to use what I need of the Track Pack harnesses and wire up a temperature controlled PWM to the differential cooler pump.
At least, that way it'll be automatic as opposed to just turning it on and off.
I'm in this so far now, I'm considering it a challenge to beat it....
The transmission cooler solution has been shown to be straight forward.
FYI,
I'm using the stock Ford parts along with a temperature controlled Weldon 9200a. All the parts I need should be here by Friday and the weekend will be dedicated to installing it.
The best thing about the transmission is that the sensor is there and supported.
FWIW,
Kirby
That's what I was afraid of... Sigh...I just verified that while the tech pack and track pack car do have the same connectors in the rear, the wiring is not there in the main chassis harness. Looks like time for another stand alone thermostat controller for the rear diff as well.
Not just to you John, but would a track pack main chassis harness be a direct replacement for the tech pack main chassis harness that would offer a full OEM diff cooler install? (someone was gonna ask, figured I'd get it out there...)I just verified that while the tech pack and track pack car do have the same connectors in the rear, the wiring is not there in the main chassis harness. Looks like time for another stand alone thermostat controller for the rear diff as well.
I would say no...Not just to you John, but would a track pack main chassis harness be a direct replacement for the tech pack main chassis harness that would offer a full OEM diff cooler install? (someone was gonna ask, figured I'd get it out there...)
