Bahndvr
Roushcharged
Repliedjust shot you over the shipping quote,
Ironair, sorry for the delay taking the measurements but looks like the tabs on my new H/E are 0.125. it was a little tricky getting my caliper inside the grille to measure, but 99% sure that's accurate.VAGunny, does yours have the same thickness mounting tabs as the old h/e and the IC tank at 0.125 or the thinner .075 like mine? I assumed it would at least have the same tabs as the lighter weight original.
Just ordered, same question. Thinking of going BND coolant route...How much coolant does it take to fill this system now? Thinking about upgrading and want to have all the supplies ready.
I went with the BND coolant when I did the swap and it seems to be working great so far. My CHT has been staying consistant around 200-205*, whereas before I was getting around 215-225*.Just ordered, same question. Thinking of going BND coolant route...
It wouldn't. Sorry, should have been more clear but I was referring to the DNB Coolant working well.Why would CHT have anything to do with a new heat exchanger for your blower? Are you inferring that keeping the intercooler brick cooler inside the intake plenum is helping absorb the heat of the lower manifold and also the cylinder heads? If that's the case, wouldn't the reverse also work? Run a really cold thermostat, radiator fans on high, and the result should be a lower intercooler brick temp? Has to work both ways or not at all.
Damnit. I just called them too and got not answer. Trying to find out the cost of getting it in black. Do you have any pricing on that from them yet?fyi, guys, whipple is telling me they are a few weeks out on these now, we've ran through the entire first batch
Gotcha ok. Had seen others in this thread say the same thing, which is why I asked.It wouldn't. Sorry, should have been more clear but I was referring to the DNB Coolant working well.
Need to datalog my next drive to see what IAT2 temps are with the new H/E and compare to the old temps. Will post that up when I get a chance.
Whipple told me an extra $50 for black powder coated.Damnit. I just called them too and got not answer. Trying to find out the cost of getting it in black. Do you have any pricing on that from them yet?
