Hack
- Nov 26, 2014
- Minneapolis
- Mustang, Camaro
Long slow application of the brake will slow the car more gradually and put less heat into the system because the brakes have more time to reject the heat as it is added into the system more slowly.Not at all. Braking technique is one of the hardest things to learn and one of the last skills to be mastered. Most people need to spend time unlearning a brake technique that works on the street but not on the track. Most common problems I've seen when coaching people:
* Braking too early, and even more common, releasing the brakes too late.
* Long, slow application of the brake pedal as opposed to a quick punch that ends with threshold braking. Beginners roll into brake zones as though they are approaching a red light. Experienced drivers slow the car quickly by reaching threshold braking.
* Inability to keep constant pressure on brake pedal while heal and toe downshifting. Data shows a lift off the pedal (but still braking) and then reapplication of the brake pressure.
All of these things extend brake zones and add heat to the system.
Letting off and reapplying will reduce heat in the brakes as well and for the same reason.
By your definitions "proper" braking technique will add the most possible heat into the braking system (assuming someone doesn't Sammy Hagar the brake/gas at the same time).
