CSL
Same track and same experience for me on stock pads. Sounds like we drive aggressively similar. You experienced friction fade as I described above. For your driving style you need a pad with more bite and you will get that consistency you're looking for. Stock fluid is DOT4, so you're good on that fluid for a few track days. I swapped my initial fluid after three track days and it was surprisingly clean. I am currently running Amsoil DOT 4.Lol, this is turning into a great thread.
Maybe it would be better if I explain what I am 'feeling' after a long session. At Pacific Raceways, there are 4 main braking zones. The first one is flat with a terminal speed around 150mph to around ~60mph, second one is 100mph+ to around 30mph (downhill) and the third is 110mph to 70mph. After a long session, I was getting a lot of pedal travel in the third braking zone, enough where it was inconsistent and I needed to give myself extra room. The pads also seemed to lose bite, but that also might be because I am used to the consistency of full race pads.
Never did I feel like I really couldn't stop, but there was some inconsistency. I am very aggressive in braking zones, often catching people in much better prepped vehicles. However, I can only do that with a very consistent brake feel. It sounds like maybe I just need to upgrade the fluid and possibly try a race pad. Otherwise I think the system is fine.
With respect to the arguments about how to brake, I have been taught to aggressively role into the brakes as fast as you can while also not upsetting the balance of the car. This was especially important on the Boss because if you got into the brakes too hard too quickly, the vehicle felt like it was going to do a cartwheel. However, with just a little patience (as opposed to stabbing) you could get a better set, which ultimately provided shorter braking distances.
Often times beginners will use their brakes too much because they are over slowing the car. The more experienced the driver, the less time you spend on the brakes even as you are going faster. This first time behavior is often a cause of overheated brakes at the track. I think this is a far greater issue than the nuance of initial brake application in braking zones.
