Wrench light code p2111
robmustang201528
15 mustang gt302blown
LA
15pp
Took it on the highway, got on it pretty hard 151 in 5th. Hit the clutch hit brakes car shows a wrench sign. Tried to give it gas but it would not accelerate. Turned the car off, started back up, took a little longer then normal, Long start. Hooked up the code sct x4, scan for codes. Code p2111 popped up. Throttle Actuator A control system stuck open. What does that mean? Do i have to buy a new throttle body? Or is it something that can be adjusted in the tune? Im gonna take it to my Tuner as soon as I can but since it's a holiday weekend I'm probably fucked until Tuesday or Wednesday. Car still pulls hard as hell like it never happened. No lights on the dash. Has this happened to anyone else? Please help thanks.
myjaja
2018 Mustang 5.0
Something similar has been happening to mine but its getting stuck closed. My code is p2112 Throttle actuator control system stuck closed. It cuts off the gas until I shut the car off and turn it on again. Im pretty sure its the throttle body. I didn't feel like taking my car to the dealership and gave me a good reason to upgrade my throttle body so I purchased a new bbk one.
robmustang201528
LA
15pp
No wrench light this time. Took the car up to 151 in 5th gear, instead of hitting the clutch immediately and the brake at the same time, this time I just hit the brakes then around 4 rpms as I was still decelerating I hit the clutch. No wrench code. I haven't gotten in to six but once and when I switch from 5th to 6th went straight into to limp mode
