Wrench light came on going down hill in nutral while going into second gear
Black22PP
Bergen County, NJ
Thomas
2022 Mustand GT
Hello all. So this happened twice within 3 months. I erased the faults the first time to see if it will happen again.
For some strange reason it happens right after going down a hill. Wrench light turns on, Exhaust mode unable to select and engine losses power. I cycled the key twice and it cleared. I was about to drive home with full power and no warning lights on. Here are the faults
===PCM DTC P061A:00-68===
Code: P061A - Internal Control Module Torque Performance
Status (-68):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
===IPMA DTC U0401:86-28===
Code: U0401 - Invalid Data Received from ECM/PCM A
Additional Fault Symptom (:86):
- Signal Invalid
Status (-28):
Module: Image Processing Module A
Any ideas would be apreciated. Im going to scedule a apointment with ford. Im hopping I can get a idea so they can diagnois it correctly. Thank You
Farkel
Cartoon City, Nirvana
Marc
'20 GT Premium PP1, 2012 Jeep JK, 2022 Harley 48
Same thing happened to me once. Parked facing downhill, started the engine and thought I'd just coast in neutral to get it up to speed, then shift into gear. Well, it threw the wrench light, etc. and I stopped and shut it off. When I restarted and drove off everything was back to normal. It hasn't happened again. I think coasting like that scrambles our cars' brains, so I avoid doing it. If I were you, I'd skip the visit to a dealer.
Racer5973
Fayetteville, NC
ray
2017 mustang gt
Engine speed and wheel speed not matching. Screws with the computer and so it throws a light.
