Window knock sound when rolling down/up
Spoolie
Spoolville
2018 A10 ecoboost
What causes this and how do I fix it?
RacinJason
Mississippi
2017 Mustang base GT w/PP
Is the sound only when the window completes the full travel, say all the way up.. thud, or all the way down, thud? If so, there is a method to re-calibrate the window travel that worked on the S197 models. From my 05 manual it says:
To re-calibrate the window, pull the switch up to raise the
window until it completes its travel and hold the switch up for 2
seconds.
lower the window until it completes its travel and hold the switch down for 2
seconds. Immediately after releasing the window down switch, pull the
switch up to raise the window until it completes its travel and hold the
switch up for 2 seconds.
Hope this helps.
Spoolie
Spoolville
2018 A10 ecoboost
seconds.
Hope this helps.
No it's when the window is about in the middle. About 3-4 little knocks
RacinJason
Mississippi
Warranty work then? Seems like a gear is worn or something like that.
