Will this work with my 9 speaker ??
Niz55
Us
17 GT350
17 GT350 9 speaker (shaker)
I like to purchase these speakers and amp and wanted to know if the will fit and work with my car.
( Front component speakers)
Infinity Kappa 60.11CS 6-3/4" component speaker system
(Front mid range).
Infinity Kappa Perfect 300m
3-1/2" midrange speakers
(Rear speakers).
Infinity Kappa 62.11I 150W 6.5-Inch 2-Way Kappa Series Coaxial Speakers
(Amp)
https://www.crutchfield.com/p_108R704A/Infinity-Reference-704a.html
mumbles
ATL
Eric
'16 GT Prem OW
(Front mid range).
(Rear speakers).
(Amp)
Yes and No depending upon how you go about it;
If you wanted to just replace the factory speakers with the Infinity speakers and drive them with the factory amp that should work. You would not use the Infinity crossovers but you would need to connect a capacitor in series with the tweeter to act as the high pass filter since in the factory wiring, the mid and tweeter share the same signal.
As far as incorporating that amp into the system, things become significantly more complicated due to the way Ford designed things. If you want a 3way system up front plus rear speakers, you will need 8 channels of amplification to have an active system. You can get away with 4 channels going passive, but not with the crossovers that come with those Infinitys which only allow for a 2way system.
Niz55
Niz55
Us
17 GT350
Is the front door woofer connected with the tweeters or the mids or are they independent?
mumbles
ATL
Eric
'16 GT Prem OW
The mids and tweeters are connected
See post one of the sticky...
