Will it fit?
bullet6236
Dallas
2015 GT
I am currently running a 20x10 +40 w/ 1/4" spacer (for the wheel to clear the 6piston calipers) on the front with 275/35/20...I'd like to know if a 295/35/20 will fit without modification?
This would ultimately be a square setup with 20x11 +50 295/35/20 on the rears.
Thanks for your thoughts and advice.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Good question, you are basically using a 6mm spacer which brings your offset down to a 34mm. It would be a tight fit depending on the actual brand of tires you would like to use and also what suspension you are on.
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
[MENTION=21053]bullet6236[/MENTION] Its very possible to be used but it is aggressive upfront, now the offsets 20x10 Et 34 is doable we do it all the time so no issues there.
Rear 295 is fine, front OD is fine, width is fine also
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
MPSS
Ultralite Linear Springs w/ Ford Racing shock/strut
(Please ignore my PM)
We have so far done with ease the 20x10 with 35mm with the R888 Toyo tires, which are fairly bulky just like the MPSS, however we have used a 285/35/20 tire size and lowered on Eibach Prokit, which is similar to your lowering springs as in ride height. You are going 10mm wider which is 5mm inside and 5mm outside, it should work..but it will be close. Hope that helps and let us know if you have any other questions, over 15 years of experience at your request. :cheers:
bullet6236
Dallas
2015 GT
It's nice to know I'm on the bleeding edge of fitment
I'll report back after my HPDE event next weekend, that should be enough testing.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
pictures as well please.
bullet6236
Dallas
2015 GT
So the tires fit with no rub. Run great at the track and look awesome.
