Tomster
Beware of idiots
I'd also check to see that the filter is torqued down to spec
I checked the lines and fittings and they're dry. The filter itself was covered with oil each time I inspected it, and it looked like there were streaks starting at the seal area. So, I concluded a leaking filter / bad seal.No leaks for me. I haven't been on track with my car, and my spirited driving probably isn't that spirited. I've done my own changes and torque the filter to spec, and recheck (cold) 100~ miles after each change.
Are you sure the leak is coming from the filter housing? Could it be from the fittings going to the oil cooler? Could it be any of the crimps on the lines to/from the cooler? There's recall on the crimps on these oil cooler lines, if you weren't aware. I hadn't seen it mentioned in this thread yet.
I think someone said but remove it and check the mating surface, I'd replaced the filter alsoI checked the lines and fittings and they're dry. The filter itself was covered with oil each time I inspected it, and it looked like there were streaks starting at the seal area. So, I concluded a leaking filter / bad seal.
You're lucky, usually whatever falls from up top doen't make it all the way down.I had to pull the belly pan last night to retrieve a socket and a couple of fasteners I had dropped into the abyss.
