TexasMetallic5.0
Thank God I made it through the 90’s and never did that.
I'll check tomorrow morning. I've got a few taps between the meth kit and the lights so I'm not sure off hand. Install was interesting. Not hard but some areas are harder to mount the lights securely. Not sure what kit you purchased but I had an assortment of lights to mix and match. I ended up using a 3ft under the front, 4fts on the sides, 2- 12" in the back and 2- 12" and a 3ft in the grill. I mounted the modules in the passanger side kick panel. It was a tight fit but worked. I've seen another kit that use one module for multiple areas. That would have been a better fit under there. LolMight be too much to ask, but you tapped into the fuse box right? Would you be able to tell me what fuse you tapped into? Got my kit yesterday and plan to install this weekend. Also how would you rate the install ? Haha I hate jacking up my car and getting fully under it
I eat rice.This is definitely in the RICE category. I don't rice.
I don't care what anyone says. I dig that!!!!
I tapped into #68 under the hood I'm pretty sure. I still mounted the controller inside on the passanger side. I'll try to take a pic of my fuse box later.I'm just trynna figure out, most people wire the Bluetooth receiver to the inside so it doesn't get wet. Problem is I already have 2 fuse taps in the fuse box passenger side for my blackvue dashcams so I'm not sure what other fuses I can tap into unless I tap into the engine bay fuse box and thats worse because I have no clue what fuses to tap
Yeah if you could later that would be much appreciated! So you wired to fuse box under the hood and assuming went through the grommet to mount under the passenger feet area ?I tapped into #68 under the hood I'm pretty sure. I still mounted the controller inside on the passanger side. I'll try to take a pic of my fuse box later.
My car normally for reference:I only had it on for a bit. The rears weren't installed low enough so it looks like im missing the rear.
Removed it shortly after as these kits were pretty bad. Will have a much better solution down the road. (These photos were from 2021).
