Whipple tuning question
Scott z
Cary il
Scott
2018 mustang gt manual
Hey friends out there with whipple stage 2.. My dyno numbers were way low last week on the first dyno session.. 640rwhp.. And 515 torq. I'm just wonderinf id whipple Accidently sent me the stage one tune.. Thise #'s are exactly what the stage 1 makes right??? Dont know if coincidence??? Let me know mustang nation.. 2018 mustang gt/ manual..
TripleB
Idaho
2015 GT Snack Pack- Whipple Stage 2
What did they rev it out to? When I did mine (15 with stage 2) it was 625whp to 7k rpm. Then I dynoed 685 reving out to 7500
Scott z
Scott z
Cary il
Scott
It was dropping off at like 6800. Its started pulling timing at 6500.. Total of 4 degrees by the end of the rev. It got to.. For an 18 gt.. The numbers should be upwards of 720++++ to the wheels.. The 15s dont have as much hp. As far as I know...
engineermike
La
2018 GTPP A10
4 degrees KR will kill your power. You’re probably losing 100+ rwhp due to that. Try different 93, try boostane, log your KR with the tomahawk and see what the effect is.
TripleB
Idaho
what gear was the pull done in?
If i'm not mistaking 18's need to be done in 4th as it's 1:1
Scott z
Scott z
Cary il
Scott
Yes exactly . I was told by the dyno guy every deg. Is about 25 horses.. So that would put me right where I should be...
engineermike
La
2018 GTPP A10
You and someone else seem to be having similar detonation issues and excessive retard. Are you sure the intercooler pump is on and water is circulating?
