Whipple replacement belt
doodguy
Ruskin, FL
2015 Roush Stage 1 Supercharged Mustang GT
Does anyone know where to get a whipple replacement 10 rib belt?
I called napa etc and they have similar for like 40 bucks but the number on the belt is not matching up.
I know I can get the belt from whipple for about 80 but trying save a few bucks if i can
TooSoonJunior
Southern CT
2015 Mustang GT PP M6
For what size pulleys upper and lower?
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
I have the 10 rib setup. 20 percent lower and 3.0 upper
:eyebulge:Christ how much boost are you seeing with that conbo? You must be making a shit load of power 950 whp:hail:
doodguy
Ruskin, FL
22psi; right about 950wheel is accurate. I made 907@6k rpmish then belt snapped =/
So need new belt to be able to get some real numbers.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Christ 22 psi at 6k making 907 whp I'd think by 7500 rpm the 1000 whp mark would be close. Again:hail:
jhatley7
2016 White GT PP, 2022 F350
I read somewhere on here, that Whipple has these belts made for them?
jhatley7
doodguy, what psi where you at when you made the 880? I'm on standard lower with 3.0 upper around 16.5 psi.
doodguy
Ruskin, FL
880 was SAE. about 908 STD. I was on 3.3 pulley 19/20 PSI.
