Where to tap into front speaker wiring
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
Hey guys,
Can anyone tell me and please with a picture show where to tap into the front speaker wire before it splits with the front tweeters so I can add my hertz cross overs and hsk165 system.
Thanks
jmr061
Wisconsin
16 Explorer Sport
Hey guys,
Thanks
Send me a PM. I will try to help you out.
Bartly
Out West
Would love it if someone posted up some photos of where to do the splicing. To the OP, if you get some help via pm can you snap some photos? Hope you get it figured out.
grumblin
Carrollton, TX
2015 Magnetic GT Premium
Hey guys,
Thanks
I had to put my crossovers in the door pockets. I used existing factory wiring to the doors and then split it off for the tweeter at the midrange. There's really nowhere acceptable inside the actual door for the crossovers because of their size so I just cheated and ran enough wire to get through the door cards. The pockets in the door cards are deep enough to completely hide the crossover - I just used Velcro and they hold great.
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
How did you wire the tweeters? How did you manage to bring the wiring from the door into the vehicle? I check the grommet and there is a connector on it. Will I have to drill a new hole or something to feed the wire?
grumblin
Carrollton, TX
I used the existing factory wiring that runs from the bottom of the factory amp. I bought a molex connector with the same pins as the amp and soldered wires that feed from my Alpine in the rear. Fed front left and right into the connector. There are a couple of very long threads here that show exactly how to do it. Fed the full signal to the left and right front woofer connection - and used that connection in the door to feed the x-over then ran wiring directly to the woofer, 3" mid and the tweet from the x-over.
pumxee
Calgary
Hamza
2016 Mustang v6 DIB
I have the base model so the wiring doesnt come down the same way otherwise it wouldve been cake. :(
