Wheel/Tire Recommendation for Budget
15wile
15wile
15 GT
Yes. Same wet/dry capabilities but quieter. The NT555G2's are more traditional looking but a bit louder. The Invo's are really goofy looking tread pattern but dead quiet. I will say they don't track as straight as, say, a Continental summer tire with a bunch of solid ribs. I'd bet the NT555G2's do a better job of providing that "on center" feel. Invo is a good tire, I would not shy from it.
Noise is irrelevant to me. The Gisbon exhaust I have on this thing is so loud that I pretty much can't even hear radio when at like half throttle. Grip, handling, roll racing, and launching... those matter. That, and price.
wildcatgoal
@sirboom_photography
TBD
NT555G2 vs. Invo - according to my research seem to have similar/same grip. Just one looks more traditional, the other looks kinda goofy. The Invo is generally more expensive.
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
I was under $1000 for wheels and tires. Got lucky with the AM wheel sale in March and got the wheels for like $80 each for 20x10 all the way around. Discount tire direct on eBay has the Nitto g2s for $400 per set with a $100 discount. So i ended up paying $600 for the tires plus another $50 or so for tax. Got 275/35 all the way around. I'd wait until Memorial Day to pull the trigger and see if LMR or AM are having sales.
But there are a ton of options on both sites that will fall below $2k. SVE GT350 package, AMR staggered package, SVE series packages, etc.
15wile
15wile
15 GT
You feel better handling/launching with that setup, over the OE wheels?
Shouldhavegotthegt
Phoenix
Much better but I also added steeda progressives, the subframe alignment, and the subframe bushings at the same time I had the wheels installed. Night and day difference.
TrackpackGT
NC
15 Mustang GT PP
Apex Racing wheels are about $1k. Cooper RS3S's might be available to wrap them in. Those wheels are about 21lbs. http://www.apexraceparts.com/apex-p...T35-APEX-EC-7-Mustang-Wheel.html#.VzzcdvkrKM8
Here's the Cooper in 275/40/18 http://www.discounttiredirect.com/d....do&fl=&pc=27157&counter=0&ar=40&rd=18&cs=275
$1700 or so total, might need a 5mm spacer for the front.
Might need to call and see when they'll have those wheels. They do have the 18x9's in stock for $199 each with free shipping.
shelbywannabe
Orlando FL
Robert
2016 Black Mustang GT PP
What is the name of your wheel ? I went on AM and wasnt sure which one it is.
Thanks
Cascadia_302
PNW
2015 RubyRed GT M6 Premium
I know with my 3.31 gears l don't want to go any larger on tire diameter. Something you may want to consider if stepping up in not only width but dia.
18's could be a very good option, but not sure what gears your running with the stock GT though?
Shouldhavegotthegt
Phoenix
Why? 235/50 is not a good setup. The car feels real floaty and there isn't a lot of grip. But I drive my car to work and around town. I don't really care about weight and performance that much. Zero track and an occasional spirit run on freeway off ramps.
15wile
15wile
15 GT
Why would that matter? I'm running 3.31.
Cascadia_302
PNW
Just that moving up to 20" wheels can change things.
My point was l didn't want to lower my ratio. Going to lets say a common 275/35-20 will net you an effective ratio of 3.27, not a big difference. lt was just something you may want to consider?
Hurricane
Coastal NC
Ted
Mach 1, '21 330i (Wifemobile)
Are you referring to how the speedometer changes because of larger or smaller diameter tires? The OEM 18" Neros I have are 27.2" in diameter according to TireRack.com. I highly doubt that I would notice any difference whatsoever while riding on a 26.8" or 27.6" or whatever diameter tire other than the speedo being off by a couple percent. That I can fix by using my SCT X4 to set the rear tire size in the car's computer. I too have 3.31 gears.
15wile
15wile
15 GT
