Wheel Spacer Install and Review
Seatown Stang
HereWeGo
Seattle, WA
Thomas
2015 Mustang GT Premium
Hey guys I have finally finished my spacers install and review and I must say...it looks hella aggressive.
[ame]
Pros:
Gives you a great muscle car stance
No vibrations or steering impact from normal
Great quality product (6061-T6 Aluminum)
No rubbing even over the worst bumps
IDK if its a placebo effect, but the car feels a little more solid while driving
Cons:
The tires do stick outside of the fender well a little causing extra spray on the side of the car(not super noticeable, but there is more)
PRG3k
Orlando
Turbo
Nice. What did you torque the spacer nuts down to?
Seatown Stang
Seatown Stang
HereWeGo
Seattle, WA
Thomas
I torqued them down to the same as the lugs on the car. 150ft lbs according to the manual
stevnoof
new jersey
2016 mustang gt base manual 3.31
I have the same spacers. I wanted to post bc I pulled my wheel off today along with the brake caliper and rotor, it has been a two months since I installed the spacers and I torqued them down to 120ftlb. when I pulled them off today four of the bolts were secure one them was completely unsecure. I torqued them back to 120 when I reinstalled them and tomorrow im going to pull off all 4 to recheck. The manual says 150ftlb but I saw a video from cjponyparts saying that the bolts should not be torqued down that much.
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
Go buy some loctite and re-torq. My instructions on my spacers said 100 ft lbs
Seatown Stang
Seatown Stang
HereWeGo
Seattle, WA
Thomas
Road Dog
Really Smart Member
St Petersburg, FL
Carl
2016 Mustang GT Convertible
After watching your video I have one suggestion for anyone else who is planning to install front wheel spacers. Use your drivers seat and a piece of 2x4 with a rag on the end to protect the seat finish. Position the 2x4 on the brake pedal and the front edge of the seat. Then simply move the seat forward to firmly press the brake. Easy and almost foolproof.
Also I torqued the spacer nuts to 120ft/lbs.
And the lug nuts to 100ft/lbs. I haven't had anything come loose, but when the Ford Techs rotated the tires 1500 miles ago I found they don't even use 100ft/lbs on lugs. So check them if you have wheels rotated.
Seatown Stang
Seatown Stang
HereWeGo
Seattle, WA
Thomas
Nice I like that idea.
stevnoof
new jersey
I used the jack as a pry bar
Seatown Stang
Seatown Stang
HereWeGo
Seattle, WA
Thomas
1380KPOI
Orange County, CA
Poi Boy
2017 GT Premium
I don't know why Bill from CJ Pony Parts would suggest to torque the spacer nuts to 120-125 ft lbs. The instructions that came with the box indicate to torque to factory specs which is 150 ft lbs. Next the instructions indicate to torque the nuts from wheel to spacer to 95 ft lbs and to NOT use an impact wrench
