Brandmotion Curb Alert Pro - Pics and Review
Discussion in 'DIY' started by bjstang, Jan 27, 2017.
  1. bjstang
    bjstang Well-Known Member
    First Name:
    Bill
    Vehicle(s):
    2016 GT Premiums a.k.a "Crazy Horse" & "Doll"
    Dec 2, 2016
    OK
    3,123
    3,036
    Garage Profiles:
    I installed this unit on my wife's car.
    PROS:
    - no drill installation
    - easy to calibrate
    - my wife likes it
    CON:
    - the unit did not come with a fuse nor a fuse tap
    The most time consuming part of the installation for me was trying to hide the wiring, buzzer, and main module. I routed all of the wiring on the passenger side of the car and used a #12 solid copper wire as a snake to pull the wires through the firewall grommet. Spaying the wiring with Lucas Interior Detailer beforehand makes it slide through easier. IMG_9539.JPG curb alert page 1.jpg curb alert page 2.jpg IMG_9536.JPG IMG_9546.JPG IMG_9545.JPG IMG_9541.JPG IMG_9544.JPG IMG_9530.JPG IMG_9532.JPG
  2. jbailer
    jbailer Well-Known Member
    First Name:
    Joe
    Vehicle(s):
    May 1, 2015
    3,237
    1,257
    Rating:
    100%
    1   0   0
    It'll be interesting to hear impressions after using it for a couple months. I put one of these on my last Mustang. When I first installed it, it was great. After a while, I didn't even hear the beep that let me know it's activated when starting the car. That's when the fun started because for some reason after a while it seemed intermittent. It wouldn't beep as I pulled up to a curb, get out look, I'm close, backup and pull forward again and it beeps... Also, for some reason it just wouldn't beep at some curbs. Then I would question, did it activate when I started the car?
    If it was 100% reliable and worked at every curb, it would be nice. After a while I was not trusting it and just stopping about 2 ft before every curb anyway.
  3. OP
    bjstang
    First Name:
    Bill
    Vehicle(s):
    Dec 2, 2016
    OK
    3,123
    3,036
    Garage Profiles:
    It has been working great since we put it on a couple of months ago. It gives about a one second beep signal when the car is turned on. Ours is set at an 18" distance and a 4" height. When the car gets within the 18" the buzzer emits 3 short beeps. Hope we don't experience the problems you did.
  4. jbailer
    First Name:
    Joe
    Vehicle(s):
    May 1, 2015
    3,237
    1,257
    Rating:
    100%
    1   0   0
    Glad it's working! Mine was about 7 years ago, maybe they've been improved? I adjusted mine about the same.
  5. OP
    bjstang
    First Name:
    Bill
    Vehicle(s):
    Dec 2, 2016
    OK
    3,123
    3,036
    Garage Profiles:
    #5 bjstang, Feb 19, 2017
    Update:
    While on a recent road trip we came across a parking situation that caused us to re-calibrate our parking sensor with a new distance. The unit only reads what is directly in front of it at the distance you have it set. When the curb is angled and the distance is set to short, it could be a problem. We re-calibrated ours to 30" to prevent this from happening.
    It's kind of hard to explain but maybe my crude drawing will help someone out. Scan_20170219.jpg
    El_Centenario and ultrahax like this.
  6. OP
    bjstang
    First Name:
    Bill
    Vehicle(s):
    Dec 2, 2016
    OK
    3,123
    3,036
    Garage Profiles:
    The parking sensor is still working well, (car on the right). Double Scoop 002 (2).JPG
  7. PKs
    PKs PK's
    First Name:
    Peter
    Vehicle(s):
    2018 GT Fastback
    Aug 20, 2016
    Gold Coast, Australia
    325
    271
    0   0   0
    Hi Bill, how is your front sensor holding up. I am thinking about installing their 5000 CA6 which has a camera as well as the beeper. I have emailed Brandmotion in the US a couple of times to verify whether it will interface with the Sync 3 display but as yet no reply.
  8. OP
    bjstang
    First Name:
    Bill
    Vehicle(s):
    Dec 2, 2016
    OK
    3,123
    3,036
    Garage Profiles:
    It worked well for a long time until a break in the proximity sensor wire, (part A). She has been after me to fix it but I haven't called to see if they will sell only that part. The break was just inside the firewall and I'm thinking when I pulled it through the opening I stretched it out.
  9. PKs
    PKs PK's
    First Name:
    Peter
    Vehicle(s):
    2018 GT Fastback
    Aug 20, 2016
    325
    271
    0   0   0
    Thanks Bill. I wish there were more reviews that I could get before committing to one of these. I guess the camera may help in situations as you described above.
    bjstang likes this.
  10. OP
    bjstang
    First Name:
    Bill
    Vehicle(s):
    Dec 2, 2016
    OK
    3,123
    3,036
    Garage Profiles:
    I need to do some research on the camera too. If you decide to pull the trigger on it would be great to hear how it works out. :thumbsup:
    PKs likes this.
  11. michail71
    michail71 Well-Known Member
    Vehicle(s):
    2018 GT 401a A10
    Apr 15, 2018
    939
    124
    0   0   0
    The thing that gets me more often is the side curb situation.
    In Florida parking lots they often have these curbed islands for trees. But then the hurricanes knock the trees down and they never get replaced. So you can't see them and run the risk of getting curb rash.
    This is where I wish we had a full on BMW style proximity system.
  12. OP
    bjstang
    First Name:
    Bill
    Vehicle(s):
    Dec 2, 2016
    OK
    3,123
    3,036
    Garage Profiles:
    Yep, it's harder to judge the distance for me with the curb located at the the right front. We test drove a 2018 Chevy Traverse a while back with a 360-Degree ‘Surround Vision’ Camera, she was impressed with that set-up.
  13. steerage250
    steerage250 Well-Known Member
    First Name:
    Ian
    Vehicle(s):
    2016 GT Fastback, 1928 Model A Ford
    Jan 7, 2016
    Perth
    228
    152
    0   0   0
    I've had one or 2 instances where mine has failed to detect a sloping curb, and I'm struggling to have confidence in it. If it had a means of indicating a decreasing distance to the object (like a regular parking sensor has beeps with increasing frequency), that would let you know it had detected the curb and then you could drive forward confidently and wait for the faster beeps to tell you when to stop.
  14. OP
    bjstang
    First Name:
    Bill
    Vehicle(s):
    Dec 2, 2016
    OK
    3,123
    3,036
    Garage Profiles:
Loading...
Share This Page
