What is the Differnce Between the Various Camber Plates??
cjgt350
Adrenaline Junkie
Central OK
2014 F250 Platinum 2016 GT350 TP
I am not sure what the big deal is. Have one alignment done while the shop allows you to make notes or paint/marker lines of the marks on the camber plates (most have alignment degree marks on top of the plate as pictured)at 0* and -1.5* for GT350 running MPSS while the R spec is more towards -2.0*. Once you take the weight load off the strut they adjust very easily by hand.
TheDeadCow
Just some guy
Gilbert, Arizona
Hot Rod
No one's worried about how to adjust the camber with the plates, it's the rest of the alignment that we're talking about.
cjgt350
Adrenaline Junkie
Central OK
You missed my point....That is what I described. Identify the desired camber alignment marks/specs on the camber plates themselves and adjust as needed for the street/track.
wildcatgoal
@sirboom_photography
TBD
exactly. Which is why I was wondering. now its alignment before and after a track day, or is there a sort of middle ground where you can improve tire wear on track, but also not toast them driving around town.
Personally, I'm still running the alignment I had when I went to Atlanta Motorsports Park! Lots of camber, little toe. No tire wear issues I'm concerned about.
TheDeadCow
Just some guy
Gilbert, Arizona
Hot Rod
I got your point, my assumption is there is a toe difference between the standard alignment and "track" alignment. No worries:cheers:
btown93
Earth
Knight Industries 2000
and caster as well. I was under the impression its not just moving the strut inboard and outboard, that other things would be affected by this motion.
cjgt350
Adrenaline Junkie
Central OK
Got it. Could be the case but I observed no discernable changes to toe or caster when we changed camber on the rack.
BoomBoy
Racer
MI
Kenny
2017 Shelby GT350, 2016 Fiesta ST
Not sure if accurate but from another thread:
Front Camber: -1.03 +/- 0.75 degrees
Front Toe: 0.0 degrees
Front total Toe: 0 +/- 0.2 degrees
Front Caster: 6.91 +/- 0.75 degrees
Rear Camber: -1.5 +/- 0.75 degrees
Rear Toe: 0.12 +/- 0.2 degrees
Rear total Toe: 0.23 +/- 0.2 degrees
As an aside, my car rolled out of the factory with -1.4 degrees negative camber at the front and -1.5 degrees at the rear.
Can anyone confirm?
Source: http://www.mustang6g.com/forums/showthread.php?p=1432328#post1432328
mitchell21
Colleyville,TX
Bill
2017 GT350R
Off topic. Noticed you have GA1R wheels. I have used that wheel in the past. Great wheel! Did you consider the slightly lighter SA1R?
cjgt350
Adrenaline Junkie
Central OK
No such wheel "SA1R" unless you meant the AR1's. Lighter yes (maybe 1lb)but not load rated for R comp tires. GA1R's in production here as well.
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
Mootang
Sacto, Caliunicornia
Henry
2017 Mustang GT
So any sponsors on here sell Vorshlag CC?
