What grit paper or disc?
Southview
Viera, FL
Herby
2015 GT Premium Convertible
I am thinking of opening the holes up on the whole grille. I do not want a delete. I like the honeycomb look. I already installed mesh vents in the hood to prepare for the added air flow. For those that have done this.. what did you use to grind back of grille plastic?
Fordever
NL, Canada
Derek
2016 GT/CS Convertible
Would a dremel tool work?
JayTea
Houston, TX
2015 Mustang GT PP
a dremel or a router works great. you can cut off 1/4 - 1/2in off and get clean lines.
Southview
Southview
Viera, FL
Herby
I thought about a dremel but it seems like it would take a very long time. I don't have a router. I was hoping to use a flapper disc or grinding disc on either a drill or air grinder.
Fordever
NL, Canada
Derek
Maybe a belt sander????
Southview
Southview
Viera, FL
Herby
But what grit paper?
Fordever
NL, Canada
Derek
Back to the original question. :doh:
I would start somewhere around 150 and see what happens. You may have to start rough and go smoother. For general sanding I usually try 150 and see whenever that takes me. :shrug:
