Bender
I would like to know this as wellWhere did you get the grommets for the roll bar through RSD?
I NEED this roll bar in my life! Looks so badass man!Got the car back from installing MGW shifter, Red 350R callipers and Watson rollbar. It was 70 degrees and didn't want to stop driving.
I'm in DE like every month traveling form CH do PL - I find your experience to be quite normal I'm afraid. Beemers are the worst, next VW Passast and the 3rd place goes to Mercedes...sometimes I wish to have some machine guns hidden under my bumper - like 007I got stuck in heavy traffic and some Mercedes kept getting so close to my rear that I couldn't see his head lights and most of his hood.
when I got space I would take off hoping that someone would get in between us. Then traffic would slow down and here comes the Mercedes again riding my butt. This happened several times before I went to exit.
He tried passing me in the right lane, which is a big no-no in Germany, but got stuck behind someone else.
Then finally, he sees that I'm am taking the same exit as he was and now I see him speeding up in the exit lane to try and cut me off. Since I got in the lane with plenty of space he again drove up my rear.
He got a final sniff of my rear in a round-a-bout. Finally I took a different exit from the circle than him.
I have no clue what his issue was, but he was really pissing me off.
I had The Roadster Shop in Mundelein install the rollbar and they had them. I will try and find out where they got them from.Where did you get the grommets for the roll bar through RSD?
You can buy the shifter directly from them. I feel a huge difference with the feel from the stock shifter.I NEED this roll bar in my life! Looks so badass man!
How do you find the MGW shifter?
Reminds me of this...I got stuck in heavy traffic and some Mercedes kept getting so close to my rear that I couldn't see his head lights and most of his hood.
Stock, the breathers from the valve covers circulate air directly back to the intake manifold. At high RPM and under heavy G-loads, oil mist can make its way into those lines and cause issues when recirculated back into the engine. The air/oil separators are basically little catch-cans and the kits include two lines each, one that runs from the valve cover vent to the air/oil separator and another higher one that exits the air/oil separator and sends the now "clean" air back into the engine through the intake.Can you explain to a noob (me) what an air/oil separator does? Why is it beneficial? Thanks!
There are versions made by Ford Performance and a variety of aftermarket suppliers and they usually run around $150 (and up) per side.
If you're going to track the car, these are cheap insurance.
Here's a better pic showing the driver side one - it's the black box about in the center of the pic just below the shock tower brace....
