What a long morning
Tamadrummer88
Tamadrummer88
Finicky
Austin, TX.
2015 Mustang EcoBoost Premium
Tire Rack shows a Pirelli that a lot of people have been mistaking for a direct replacement tire, but it's not the same one. Make sure you're looking at an exact replacement. I can't speak for your dealer, but most that I know do not have large mark-ups on tires. Tires never really have a whole lot of mark up in them...
The one I saw was 255/40/ZR19 96Y and it stated original equipment. Dealer was asking $314 per tire, and tire rack had it for $261 per tire. Dealer told me tire rack price was below dealer cost.
Asharus
Boca Raton, FL
Angelo
2018 Challenger Scat Pack
Hopefully you get the idea from the potato pics, the lighting isn't the best in my shop for pics inside a trunk and my phone didn't want to flash.....
Distance from the trunk floor to the top of the liner when it's on the tire is exactly 3". I think I'll get another liner this winter and cut it to slip over the spare, could look pretty neat IMO. Regardless, it's better than no spare.....
thanks for the pics. doesn't look that bad at all.
BBB
Potatoville
Premium GT Poverty Snack
yeah, i'm going to pass on the PP wheels in trunk, looks silly
It's not my daily so I'm not as concerned about it
Asharus
Boca Raton, FL
Angelo
the better solution might be just getting the ford spare tire kit, and a wheel spacer.
OEM spare tire will fit the rear if you get a rear flat, and if you get a front flat, put the spare on a rear wheel, and mount the rear wheel temporarily up front with a spacer.
z06psi
Evans, GA.
Andrew
The pot stirrer
Kam highway going from Pearl Harbor to Waipahu and then Farrington from Waipahu to old Ewa Beach is absolutely covered in steel plates and huge potholes from the stupid rail construction.
Was down through there this morning. Didn't go over 20 mph.
Tamadrummer88
Tamadrummer88
Finicky
Austin, TX.
I avoid those areas like the plague. Even if it means taking a side road and sitting in traffic .
Tamadrummer88
Tamadrummer88
Finicky
Austin, TX.
What size is the OEM spare?
Old Car Guy
WV.
GT350 Tech Pack. AG Black Roof Black Stripes G3597
Is......
Is it possible to just order the Ford spare tire and rim for a none PP car, were it will fit where the spare tire goes, And also just ordered a wheel spacer so it will work, on a PP car to use for your spare if you have a flat tire, I'm just curious it's hard for me to think, but I was trying..... Ha! :shrug:
Asharus
Boca Raton, FL
Angelo
jrt6
Houston, TX
2015 White Ford Mustang GT Premium, 6MT
The OEM spare is a 18" tire. I bought it and I have the 20" foundry wheels. If I get a flat on a rear I'll have to take a good tire from the front to put on the back and put the spare on the front. I read on here that different tire sized can damage the rear diff because it's a limited slip.
Tamadrummer88
Tamadrummer88
Finicky
Austin, TX.
I have an American Muscle PP replica front wheel with a stock size tire (255) mounted on it, and it fits the spare tire recess snugly. It sticks up from the trunk floor about 3" or so when in the recess.
I just thought about this. What about a 19x8 wheel as a spare? How far over the well would it stick out compared to your 19x9 with a 255?
Asharus
Boca Raton, FL
Angelo
as long as the circumference of the tire is roughly the same, it should be fine for short distances. if your front 20" tire is the same circumference as your rear, there's no need to swap
Blk2015GT
2015 GT
It's a 20" wheel and 18" wheel, not overall diameter with tire. The sidewall is taller on an 18" than a 20"
Even the OEM 18s (which Ford sells the spare for) are 235x50R18 which are 27.3" in diameter and the spare which is 155x60R18 is still 2" shorter (25.3") in diameter, so I don't see the difference using it for 20's on most tire sizes. My 20s aftermarket on 275x35r20 are 27.6" tall, so only .3" larger in diameter than the OEM 18s. I don't see any harm using the spare then.
I think its better, but not necessary, if you can keep the spare on the fronts to keep load off of the diff though. It's easy, jack up the front put on the spare and take off the good wheel/tire. Jack up the rear and take off the rear flat and put on the front good tire/wheel and done. Then get a new tire on the wheel and put it on the front to replace the spare.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
FYI, the American Muscle wheel I used is 19X8.5" versus the OEM 9".....
The reason I went this way: no spacers, no nonsense. Bolt on either end of the car and go.
Tamadrummer88
Tamadrummer88
Finicky
Austin, TX.
That makes sense.
