Went to track help me what broke ??
stang305
Cape Coral, FL
2015 Mustang Gt
went to the track yesterday first time with the boosted stang on stock clutch. On my 2nd run the clutch went all the way to the floor. And would not allow to put into gear with the car is on. When trying it sounds like a clunk noise and will not allow to go into gear. When the car is off I can push the clutch and go into gear.
Also clutch feels way different it’s way lower than usual.
Thanks for the help
Calvin
California
17 GT PP
Had a similar problem recently. Turned out I exploded my hydraulic throwout bearing. It was completely seized and the bearing had tons of play. First symptom was after a shift and the pedal lost pressure but I was able to pump it back up. Second high RPM shift, pedal stayed to floor, and had visible fluid leaking on ground. Happened on the street in the country. Didn't have phone so had to literally let the starter crank the car to life at every stop and clutchless shifted it back home.
I am procharged also but I have a Tremec Magnum XL and Spec Super Twin clutch so its not exactly stock, but nevertheless the OEM spec hydraulic throwout crapped out on me.
Other thing it could possibly be is the clutch master cylinder.
stang305
Cape Coral, FL
2015 Mustang Gt
I plan on upgrading the clutch to an RST just to be on the safe side. do i buy an OEM clutch master cylinder as well or is there a better alternative? want to prevent this from happening in the future.
Calvin
California
17 GT PP
I am still on the OEM stock master. It has leaked slightly onto the interior carpet since I got the car new and have 30k miles now, 8k of which were on the new clutch. At the very least replace the pilot bearing and hydraulic throwout/slave assembly.
moffetts
San Mateo CA
Black Whippled 2015 GT PP
Whether this is the TOB failing or not (sounds like it is) you would be very wise to replace it when doing the clutch. You have to drop the transmission to do the TOB anyway.
Bridgie
Raleigh, North Carolina
2015 GT fastback. PP, 50th trim, Black
I hope its not this..! My Stock clutch went on track... The opposite side was clean with minimum wear..
I replaced the complete clutch system with Excedy Stage 3, lightened flywheel, Master & Slave, TOB, Hard lines, fluids....
TrevorGT
WI
race red 2015 GT
It’s the clutch disc. When mine came apart, it acted exactly like you’re describing. Only could shift when car was off.
96gt4.6
Kansas
2017 GT Premium/A6, 2020 Explorer ST
Clutch Disc. Seen and done many of them, the symptoms are nearly identical.
