Water leaking between window and A-pillar
hunter121496
Daytona Beach, FL
Hunter
2017 Mustang GT Performance Pack
Anyone have any experience with this? I’ve seen posts with water leaking from rain in different spots, but not here. It’s on both sides but thankfully it doesn’t rain in Arizona too much. Any help would be appreciated!
(Not a convertible btw)
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
I usually sit inside the vehicle with a bright flashlight, and have someone on the outside pouring water over the area (hose) and look to see where the water is coming from. That should point you in the right direction. Depending on what you find, will help decide the next step.
hunter121496
hunter121496
Daytona Beach, FL
Hunter
Yeah I believe it’s leaking through where the window meets the seal on the A-pillar. Wasn’t sure if anyone else has had this issue before.
Mike Pfeifer
Wesley Chapel, FL
If it’s coming between the seal and the glass, then it’s either the seal is damaged or dried out or something like that. Or, the glass is misadjusted and allowing water through. I have not heard many complaints of either on here, so not sure which way it would go for you. If, however, the water is coming from behind the panel instead, then there is another deeper issue and will maybe require further investigation.
Garfy
Utah
Gary
Being that you are in AZ, I wonder if time has affected the weatherstrip seal where it's dried out or not as pliable as it was. There are products that you can apply to the rubber to rejuvenate or help soften it so it will seal better without causing the seal to stick to the glass. My car is garaged and I haven't yet applied my seal restorer yet which I found on Amazon.
hunter121496
hunter121496
Daytona Beach, FL
Hunter
Yeah mine has been garage kept the whole time I’ve been here but it’s definitely a possibility. I’ll check that out, thanks!
hunter121496
hunter121496
Daytona Beach, FL
Hunter
