Jpol908
- Dec 12, 2016
- New Baden, IL
- Jason
- 2018 Mustang GT Premium 401A Ragtop
Hi all,
I have the Ford Performance Procal on my Ecoboost (2015 Auto, 3.31 gears), along with a DV+ WITH optional spring installed.
Car seems to run well, with boost "kissing" 25psi under full throttle. Boost definitely went up a bit from 21-22psi on just the tune, to the 24-25psi after the DV+. However, the car still feels a bit laggy from a dead stop. Won't even break tires loose on bleach water in Track mode. I haven't had it at a track, but best 0-60 I've seen is 5.6 on the car's track app.
It does still seem a bit slow to spool up the turbo, about a second to spool.
Question is...
1. Is that normal to spool like that?
2. Would a new Wastegate Actuator help?
3. Will said Wastegate Actuator play nice with the Ford tune and DV+?
Question is...
