Warning light?
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Are the front tires the SAME O/D SIZE as the rear tires? I run 325's on ALL 4 tires and DON'T have a LIGHT!!!
This only happens when the rear tire size changes to a smaller tire. Fronts would not cause the issue.
Cgouzoulis
chris
None
or a larger one....
Cgouzoulis
chris
None
I am assuming OP does not have an Nguage or end user tuning device to correct said height issue on their own. These are nice as if you were to go on a cruise or different driving type other than drag, you could easily adjust yourself. Having to take to a tuner every single time you changed your tire/wheel setup would seem quite tedious.
protraxduner
OK
2020 Shelby GT500 Race Red
If the front and rear tires are the same OD then obviously there is another problem. But since he is running DR then likely they are different OD.
Stock front = 27.2
305/45/18 street R = 29
325/35/18 street R = 27
If running 305 Street R then FOR SURE tires difference.
If running 325 Street R and stock fronts then i would NOT think it would throw light.
