Vortech owners
robmustang201528
15 mustang gt302blown
LA
15pp
Anybody running V7JT vortech blower? Anybody using a torque booster? What are your thoughts? Hp and Tq numbers?. I just bought this step up with 1000 pound injectors. Anybody with similar mods?
beefcake
Bethel
2018 Ford Mustang
lots of guys running the jt, depends on the spring setup and fuel as far as power
robmustang201528
LA
15pp
Spring set up? What does that mean [MENTION=10926]beefcake[/MENTION]
ahl395
Allan
When using a "torque booster", AKA a wastegate on the intake pipe, the spring in the wastegate (as well as the pulley on the blower) change the amount of boost you'll see and the boost curve.
With that setup you pulley down for more boost than you intend to run, and bleed off the extra via the wastegate, which makes boost build sooner.
Generally, your fuel will dictate how much boost (and therefor what spring) you can run. What fuel will you be using?
robmustang201528
LA
15pp
This is my set up .
Vortech jt trim v7
8 rib pulley upgrade
Id1000 injectors
JLT intake for vortech kit
VMP boost a pump
Beefcake torque booster kit (turbosmart hypergate45 wastegate)
Turbosmart e-boost boost controller
3.15 pully
