Vortech aftermarket intercooler?
nameuser
Ohio
Jesse
2018 PP2, 1969 Chevelle
its done, it was built off the 2024, but were watiing for someone with an s550 for testing that can get us some data
You still in Ohio? ;)
Angrey
Coral Gables
2016 GT350
Does no one make an A-W-A intercooler and heat exchanger for centris and blow dryers?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I did a custom air to water setup on my centri. But no room for heat exchanger so it's simply an ice water deal. I don't drive a whole lot on the street, the amount I do has been fine with no exchanger. But once the water gets hot, you must dump it and put a bag of ice in. I've only had to do that once.
beefcake
Bethel
2018 Ford Mustang
we need someone to test this that is monitoring boost before, and after the intercooler so we can see the boost drop if any
nameuser
Ohio
Jesse
Hey @beefcake any update on your 1400hp intercooler?
beefcake
Bethel
2018 Ford Mustang
still waiting to find someone that can log iats and boost pre and post interocoler
robbo810
Australia
Nathan
2020 Mustang gt Vortec v7jtb 10r80
Terry im Currently setting mine up to monitor pre and post intercooler psi through vcm scanner on my 2020 gt premium with vortech v7 jtb, 3inch pulley. im only getting 1.74 airload from 6400 to 7500 rpm so im thinking the stock vortech intercooler is a restriction. id be keen to test it for you however I'm in Australia.
cbrtrx
tampa fl
2016 mustang gt
I don't think the intercooler is causing that restriction. Possibly belt slip or a tuning issue.
robbo810
Australia
Nathan
its tuned by lund and its got all griptech pulley ars tensioner 8 rib and there is minimal rubber from the belt near the pulley?
cbrtrx
tampa fl
2016 mustang gt
I've seen that vortech intercooler support 1100 rwhp with a jtb on 21 pounds of boost. It went much higher then 1.74 air load.
Now going down the track it needs meth because the intake temps get too high.
Justa3v
Calgary
07 mustang gt, 2015 edge sport tuned
Hey, Terry. Whatever happened with this Intercooler? I maybe needing an upgrade for my new ysi-b.
