Vland Multi-Mode Clear Tail Lights
Do you prefer stock red or clear/smoked tail lights?
  • Total voters
    39
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
https://www.vland-carlamp.com/LED_M...ord_Mustang_Clear_Lens/p4995994_19940473.aspx
Just installed a set of these clear multi-mode Vland tail lights and wanted to post some install tips because the Chinese instructions suck, and I couldn't find any tips anywhere else on 6G or Youtube.
First lesson that I had to learn was that our U.S. Mustangs are "USDM" (United States Domestic Market I believe). Important because the instructions have steps for USDM cars and for non-USDM cars.
Physically installing the lights is really easy:
1) Open the trunk and unscrew (4) knobs from the back plastic trim piece that surrounds the latch. Lift the trim piece up and out. It has 2 snap tabs and 4 hooks.
2) Remove (1) trim push pin from each side that holds the carpet trim in place. There are magnets (!) holding the rest of the trim to the sides of the car.
3) Remove the carpeted spare tire / inflation tank cover.
4) Unclip the wiring harness connector behind each light.
5) Remove (3) 10mm nuts on each side and slide the lights out of the car. The harness passes through a rubber grommet; just push the whole grommet out from the inside so you can pull out the harness.
6) Remove the black plastic water drain trim piece from the top of each factory light for installation on the new lights. There are two snap tabs that hold it in place, I used a trim removal tool to gently pop them off.
Installation is easy and is the reverse process.
BUT.... there are other wires that come with the kit that make the install a PIA. There are two short (6" long) harnesses with a connector on each end. THESE ARE FOR NON-USDM CARS and are not used. It took me a while to figure this out. There is also a long yellow wire that DOES get used, it gets connected to the high mount 3rd brake light. How, you may ask? EXACTLY. What a pain. The instructions are useless - they basically say "plug it in". Here's what I did (luckily I had recently installed new rear deck speakers or wouldn't have figured this out):
A) Fold down the 2 rear seats.
B) Pull the plastic trim piece that surrounds the top of the seat belt away from the plastic base on each side.
C) Gently pull the two side plastic trim panels away from the car. There are several clips holding them to the side of the car. They are attached at the door sill so don't pull them away that far. Be careful because they will scratch up the plastic C-pillar trim (on each side of the rear window).
D) Remove (1) plastic push pin from each side of the rear carpeted deck, they are hidden behind the two side trim panels.
E) Pull the rear carpeted deck towards you to remove it. There are gray foam pads that are crappily glued to the bottom of the deck, a few fell off when I removed it.
F) Now sit on the folded-down rear seats facing the front of the car and gently bend down the headliner in the middle where it meets the rear window. You will see a small black plastic connector that looks like the connector on the end of the long yellow wire. Unclip the factory connector and clip the ends of the yellow wire into the factory connectors.
G) Gently pull the driver's side C-pillar plastic trim away from the car near the rear window, but don't totally remove it, there is an air bag in there. I ran the yellow wire under the headliner and down the top edge of this trim piece. At the far back driver's side corner of the exposed metal rear deck is a small slot, about 1-1/4" long x 1/8" wide. This slot is where I ran the yellow wire into the trunk. I looped it around the rear-most pointed end of the C-pillar trim and snapped the trim back into place, then reassembled the rear trim panels, rear deck, and seats.
H) Now that the yellow wire is in the trunk, it's super easy to run it to the driver's side tail light connector and then across to the passenger side. There are small push-pin connectors, no wiring or splicing needed, just plug it in.
Reassemble the trunk trim and you're done. TOTAL pain but without that 3rd brake light wire, the tail lights lit up but didn't work right. When you hit the brake, the lights would turn yellow for a second and then turn off.
Programming note: Mode 5 is called "Factory" in the manual but it includes yellow hazards and turn signals so that must mean factory in China or something. I kept thinking I wasn't programming right because I was trying to program to "Factory" but kept seeing yellow lights. Mode 3 is USDM (all red) and acts like our U.S. factory lights.
OK between typing all this and installing the lights my fingers are tired AF. Good luck guys, hope this helps someone out.
ChaoticFury09
Toronto Ontario
Nathan
2019 GT Premium (Automatic - Magnetic)
Thanks for the write up. I just did this last weekend so these tips would have been good but I got it figured out on my first go. Wish it didn't have to connect to the third brake light. I was about to make a separate post about some issues I am having. Wondering if you can check for the same.
1) Is there a delay between when you press either the left or right signal and the time it takes to turn on the sequenced tail lights? Mine takes a good full second so I realize how dangerous this must be if I am driving and want to change lanes quickly. It is going to look like I am not using my signal.
2) Do you get the same radio without static or reception issues? Some of the channels I realize have been giving me static where I did not have that previously. I plan to disconnect the third brake light and try the radio sometimes this weekend to see if I can get that figured out. I tried it over different days and different weather conditions so it wasn't that.
Mikepol2
Mikepol2
Pittsburgh, PA
Hmm I haven't driven it yet so not sure (just checked it out parked in the garage) but if I notice either of these things I'll post about it.
ChaoticFury09
Toronto Ontario
Nathan
Here is a video clip of it a few different ways. Being by myself I had to use the reverse camera but you can hear the signal and then see the lights in the rear view camera. The other video I have is when I lock the car only two of the bars light up. Let me know what your experience is.
Mikepol2
Mikepol2
Pittsburgh, PA
I will say that trying to change modes is extremely difficult and frustrating. I must have tried 15 times so far, and have only been able to make it change one time. At this point, I’m not even really sure what I did to make it work that one time.
ChaoticFury09
Toronto Ontario
Nathan
I had a hard time as well. The 4+ mode is confusing for sure. Basically if you follow it exactly as the instructions state it should work. So if you are on Mode 2 for example and you want to get to mode 3, it's 4+1. Since you are moving from 2 to 3. That's my understanding at least.
Mikepol2
Mikepol2
Pittsburgh, PA
I can confirm that although there is a delay when I turn on the hazards, the turn signals light up almost immediately when I turn on the stalk.
I think I figured out the mode change... you have to turn on the hazards like RIGHT NOW as soon as you are done flipping the lights on and off. And it seems to be that you flip the lights not based on what mode you are currently in, but on the mode numbers in the manual.
ChaoticFury09
Toronto Ontario
Nathan
Are you saying you don't have the same delay I do with the turn signal? If you reference my video.
and with regards to the modes if you want to get to mode 3 it's 4+3 so 7 regardless of the mode you are in?
Mikepol2
Mikepol2
Pittsburgh, PA
Yes to both. Haven't driven it yet to be able to test for radio static, but as soon as I touch the turn signal it starts to blink.
ChaoticFury09
Toronto Ontario
Nathan
Interesting. Same mode?
Since I was on my own I had to do it from within the car. As you can tell by the video it isn't synced to the sound of the turn signal like the OEM lights. So the only way I was able to verify was to visually check.
Mikepol2
Mikepol2
Pittsburgh, PA
Right now I'm using Mode 4, amber sequential. It also worked on Mode 3, all red USDM.
ChaoticFury09
Toronto Ontario
Nathan
That's the same mode I am on. I may try to change the mode and then switch it back over and see if that fixes it. Interesting that it is the same mode but different results. Odd.
Appreciate you confirming.
ChaoticFury09
Toronto Ontario
Nathan
I got a friend of mine to check mine today. Turns out there isn't a delay. I am thinking the time between the camera and the display is causing the delay. Radio seems to have sorted itself out. So should be good to go.
Mikepol2
Mikepol2
Pittsburgh, PA
Excellent!! Glad you got it sorted out.
ScubaSteve2020
Dublin
2019 Race Red Mustang GT
I installed the non-USDM Vland tail lights. That yellow wire for the third brake light isn't required on our installs.
One problem I've found though is that the turn signal in any of the dynamic modes (cursor mode is my favourite) is very faint when you have the brake on.
