valve cover leak?
Litefoot
Spring, TX.
honda,Mazda,GMC
2016 gt pp
31k miles
noticed small oil leak driver side, seems to be leaking onto exhaust manifold, I assume it's the valve cover leak a lot of other owners have
looks like I can
a: check bolts and tighten to spec
b: pull valve covers drill out 4 holes both sides to add the bolts Ford should have put on to begin with per tsb
https://www.mustang6g.com/forums/attachments/tsb-19-2309-5-0-valve-cover-gasket-pdf.520195/
https://www.mustang6g.com/forums/attachments/5-0-valve-cover-lh-pdf.401026/
https://www.mustang6g.com/forums/attachments/5-0-valve-cover-rh-pdf.401025/
c: replace valve covers with ford performance m-6067-m52s aluminum cam covers
https://www.lethalperformance.com/f...cPPh0alVzFJrYzU9EF1LVvlIddyAehHRoCmQoQAvD_BwE
this seems like the more permanent solution, however noticed warning on part description
FOR CLOSED COURSE COMPETITION USE ONLY. NOT INTENDED FOR STREET USE. THE SALE, USE, OR INSTALLATION OF THIS PRODUCT MAY ALSO BE ILLEGAL NATIONWIDE UNDER THE FEDERAL CLEAN AIR ACT (42 U.S.C. § 7522(A)(3))
questions are
1: if I change to aluminum covers will I have problems with state inspection
2: do I need special tools described in service manual to do the job
T80T-4000-J)
Installer, Differential Bearing ConeInstaller, Differential Bearing
T80T-4000-W)
HandleH
VCT Spark Plug Tube Seal Remover and Installer
TKIT-2006UF-FLMTKIT-2006UF-FLM
TKIT-2006UF-ROWTKIT-2006U
lkeltner
KS
Lance
2017 GT PP1
Getting ready to order the aluminum covers myself. Did you end up needing the special tools? or just swap and go?
Edit: 2-14-23. No special tools were needed. It was a royal pain to get all the k brace and battery tray stuff out, but it all went back together ok. 6hr job :( On my old fox body it would have been something like 20min :)
