Vacuum for fuel pressure regulator
1quick
Illinois
2016 mustang gt tvs
Where are you guys picking up your vacuum at I’m working with a roush blower, looks like the hose going to the boost bypass valve would be the easiest, on other cars I normally go for something on the lower Intake manifold though
oesman
Houston, TX
Dmitry
2016 Mustang GT PP
I went with the vacuum line coming from behind the throttle body plate. In this setup your FPR would see vacuum and boost.
rts9364
KS
2015 Oxford White GT
I just laid mine out last night. I'm installing along with a Procharger. The PC kit installs a vacuum manifold right off of the factory vacuum block (wrapped in sticky foam near the TB). The bypass valve and boost gauge both come off of the new vacuum manifold, so that's where I'm getting vacuum/boost for the Fore regulator and the Hobbs switch. I'd think tapping into your bypass line would work for you.
z06psi
Evans, GA.
Andrew
The pot stirrer
:thumbsup:
