USB ports not working
demarad1
Windsor, Ontario
2016 Ford Mustang GT Premium
Hey folks....apologize if this is posted in the wrong area....
Neither of my USB ports seems to work. IPhone 6 doesn't connect when plugged in, no charge showing on the phone, and other memory sticks aren't workin either.
Has anyone had this issue, and if so, what did you find out was the root cause?
Thanks for your time folks!
demarad1
Windsor, Ontario
Holy cow.....76 views and nothing? Lol, I guess it's a fluke....which I suppose is a good thing....too bad it happened with mine!
sandpiper
Long Island, NY
2015 Ecoboost Premium
Check the USB wire?
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Reset the system?
demarad1
Windsor, Ontario
Ya already reset sync3. Not sure what wire you may be referring to. I would assume let ford look at it given its 3 weeks new....but what a bummer. I sort of wish others had this issue so I could be reassured it's not a major wiring problem. Lol
demarad1
Windsor, Ontario
update: so car has been in the 2 days now....they had to contact engineering, given the schematics they had were not accurate, and they wanted ford to replace the media control hub or module. part is on order, and they will test it after that has been installed. standby for further update in the event someone else gets this issue.
GoBlues38
St. Louis, MO
Scott
2015 Mustang GT, Premium, 3.55, 20" Foundry, 6 Spd
make sure you usb cables are good. cheap Chinese knock off cables are known to have issues.
demarad1
Windsor, Ontario
The USB ports do not pick up any device, any cord, and usb device etc. in my case in using the iPhone lightning cable and an iPhone 6 and it charges, but does not pick up a connected device.
