Under coating, anyone done it themselves?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Im thinking about doing under coating myself with a high quality can spray type. If anyone here has done it let us know how it turned out!
tsunami
Minnesota
2015 Premium EcoBoost Convertible
Most do-it-yourself canned underbody treatments go on like tar. The flexible thick coating usually begins to loosen, allowing water and salt to work its way between the layer and the vehicle greatly accelerating corrosion. The underbody treatment should look and feel like hardened paint.
In addition, you would need to drill holes to spray into cavities. Don't spray into the doors. The underbody coat will gum up the window mechanisms. Professionals use a 'wax' type coating in the doors that inhibits corrosion but won't jam the windows.
If you can afford, it have professional undercoating done...you won't have to spend days...and you usually get an extended corrosion warranty.
Lost
Upsate NY
2016 GT Premium 6 speed blackout /3.55
Unless you use the kit I posted immediately above your post. Goes on like melted butter.
WhiteyDog
WOOF!!!
Manheim, Pa.
I used POR15 on past projects. Super stuff, not cheap, goes on thick and dries smooth. And if you do the inside of your trunk, with all the fumes in there, you will get really gooned. I looked at it as a fringe benefit of using it. Heh, . . . . .gooned.
Snowstang
Newbury, Ma.
2005 Mustang Coupe
I used Kano Weatherpruf , it is relatively clear drys to touch . It looks like new after one year, I do drive the car inNew England , so it gets a salt bath. I used 2 cans
