Unbelevable slop in drivetrain
VinnAY
Kansas City
18 Camaro 1SS/1LE
Im going to try it myself ive read that the Differential and subframe bushings (Steeda) can clean up things nicely in this regard.
Enzo
Orlando
Enzo
2018 Mustang GT PP1
I have those bushings it helps greatly. The rear is quiet, in extreme cases the noise would be very faint.
Sent from my SM-N920T using Tapatalk
dallas70
DC
'15 GT PP Magnetic
Would what I'm describing below be the backlash you are talking about?
When traveling slowly (~5mph) and I depress the clutch, I can hear shit banging around underneath. It sounds like backlash, because I can use the gas to sort of "relieve" the drivetrain of the torque right before I engage the clutch and I don't hear anything. Also, I can hear the same thing the exact moment the back tires get over a speed bump while going real slow. Exact same noise. Doesn't happen when the front tires go over, only the back.
Exactly what I'm hearing/feeling from my car. Gave it a year and almost 15,000 miles before having the dealer check/verify that what's going on is "normal". Never drove a manual this "sloppy". At dealer now...we'll see.
VinnAY
Kansas City
18 Camaro 1SS/1LE
Having mine installed now the audible-ness is greatly diminished.
Mike A.
Purcellville, Va
2015 GT/PP
I have a very sloppy drive train. My '11 GT wasn't anything like this. After installing my Steeda bushing inserts gear whine from the rear diff has gotten pretty loud when on the hwy decelerating in gear. I could hear it a tiny bit before but now it's loud.
Wheel hope is gone but now I have gear whine..... :frusty:
wildcatgoal
@sirboom_photography
TBD
BTW, ya'll, changing the oils in the trans and rear didn't reduce noise enough to have made it worth the effort, so..... don't bother unless you actually need a change.
ForTehNguyen
Houston, Texas
15 GT
after MGW shifter, new fluid, steeda diff inserts, the thud is more like a quick bonk now.
JuRuKi
SoCaL
2016 GT/PP
Sorry to bring up an old thread. I was start a new one when i found this.
When im in gear and let go of the gas and accelerate again i hear and feel a thud like there is a little bit of play/slack. Is this normal?
scoggy_doogan
2016 GT Premium
Mine does this too sometimes, but only in 6th. I have no clue if it's normal but I've never had a car do it before.
JuRuKi
SoCaL
2016 GT/PP
Mine does it in most of the gears.
EXP Jawa
Rochester, NY
www.torsen.com
Rick
1999 Cobra Convertible, Electric Green
A small amount of play is normal in a RWD driveline; there needs to be clearance between parts so that they can be assembled and run properly. But it shouldn't be excessive. The distinction between "small amount" and "excessive" is highly subjective, it would seem...
