key01
- Nov 10, 2017
- Chicagoland
- 2017 GT350 now gone to a great home.
Man, no dealer seems to be able to get this stuff right it seems. Sucks.
Have you checked it when it's fully warm after letting it sit for 15 minutes, as described in the manual? It does look high, but it may still be fine once it's warmed up.Hey Guys, not sure if anyone had been following, but my engine blew up because of a dropped valve.
However, the dealer swapped the engine and I've been driving my car for a week. Before I picked it up, I checked the oil and it was exactly between the two holes.
I checked it again this morning and it was clearly overfilled. Maybe they had run the car before I checked it at the dealership and the oil didn't have to drain back to the pan. When I checked it today, it was after the car was standing overnight.
I have attached some pictures below. Does this look acceptable? I would hate for oil to find it's way to the crank, foam up and blow another engine.
Yes I did! I first checked it when I returned home after a drive yesterday. I checked it 15 minutes after I shut off the engine and the level was high.Have you checked it when it's fully warm after letting it sit for 15 minutes, as described in the manual? It does look high, but it may still be fine once it's warmed up.
What's the worry from my readings that flat plane will burn thru that in a no time.Yes I did! I first checked it when I returned home after a drive yesterday. I checked it 15 minutes after I shut off the engine and the level was high.
I again checked this morning and the level was very similar.
I guess we all need a wise guy in our lives.What's the worry from my readings that flat plane will burn thru that in a no time.
Well, then, it's over filled. If you're DIY-enabled, it's really easy to lower the level a quart or two so you can get it right. If not, then the dealer's the best option.Yes I did! I first checked it when I returned home after a drive yesterday. I checked it 15 minutes after I shut off the engine and the level was high.
Aw ok a 350 owner .I guess we all need a wise guy in our lives.
Been there, done that, couldn't make it work. I tried to do an oil sample that way and the dipstick tube is so narrow that it won't allow the plastic tube to go down. I tried a number of different tubes and in the end I concluded that a plastic tube that's stiff enough to go down is too fat to fit, while one that's thin enough to fit is too limp to make it to the bottom.Or for a few bucks you can go to the hardware store and buy a hand operated fluid removal kit that has a thin hose that will fit down the dipstick tube and take out the excess oil that way. Less messy, no lifting required.
