reugre
Hi Guys,
In a bit of a dilemma in making sure we are doing this right.
Some background info first:
I've had a sleeper (bottom mounted) twin-turbo fitted about a year or so ago, running wastegate spring boost. I first had both waste gates on 7PSI springs and later changed them to 10PSI springs all tuning so far has been done by Palm Beach remote tuning.
Car is 2017 GT with 2018 intake manifold running 2 x 62/62 oil-less turbos from Comp Turbo bottom mounted (sleeper).
Hub Dyno figures using pump gas:
With 7 PSI WG springs it made 636 WHP
With 10 PSI WG springs it made 732 WHP at 5700RPM (probably more if we were able to do a full run but clutch started slipping and we couldnt get a dyno run past 5800)
I must admit it's mad driving it and sometimes does scare the heck out of me since I upped it to 10PSI. So I have now decided to replace the Mcleod clutch to the Lethal performance clutch 1000 rated and most importantly install a boost controller and drop the springs back to 7PSI so I can do normal day to day driving on lower boost with the benefit of being able to up the boost when ever i want that extra power with just a click of a button
Sorry for the long story but since i never really posted here i thought i would give a bit of background before i get to my question.
So my question is related to which install diagram should we follow because when looking through the turbo smart installation instructions there are like a million options to choose from.
I figured out that for a V configuration I should be using two solenoids (apparently).
My first question was which configuration should I be using to install the boost controller. Below are the installation diagram options which I believe are relevant to my setup.
Option 1 - Twin Solenoid (as below)
Option 2 - Single Solenoid (as below)
Option 3 - Twin Solenoid for High Back pressure (as below)
Option 4 - Single Solenoid for High Back pressure (as below)
Any idea which of the above install diagrams should I follow.
It is important to note that I am getting my vacuum reference from the inlet manifold just after the throttle body because I have not tapped the turbo compressor therefore I am using a vacuum block to connect all the vacuum hoses to it (i hope this is ok)
Many thanks
Reuben
Many thanks
Reuben
