Turbo Upgrade First? Or Bolt Ons first?
evan546
2015 Mustang Ecoboost
Ive been debating on either buying a turbo upgrade first or bolting on first i currently have an intake tune and exhaust. I just though that i might aswell get the most expensive part of the list first or is this not the way to go?
Nihil
Cowabunga
Roanoke, VA
Grey Goop
first you need an intercooler, and I would suggest a more free flowing catback exhaust. Turbo upgrade kit will have new cai and downpipe, unless you want a stock size turbo upgrade, still recommend bolt ons first.
evan546
I had the Cavalli upgrade in mind
Tune+
St. Paul, MN
www.facebook.com
Adam
2015 Ecoboost Mustang Automatic
You need to determine if you want a stock location turbo upgrade or a big turbo upgrade which replaces all the factory components. If you do a big turbo upgrade you will get a downpipe, intake, and pass side charge pipe in the kit so all your stock turbo upgrades will be useless.
evan546
I want to do a big turbo after my warranty is up just a stock location for now is what i have in mind
Tune+
St. Paul, MN
www.facebook.com
Adam
Well if you are going to be purchasing both, then what is this post for? If you do stock frame turbo now, then buy all the bolt ons for it. Then when you go big turbo upgrade you will just swap everything out.
Stevem627
Dallas, TX
2015 Ecoboost PP AT
I think if you're going to run a larger turbo, you had best make sure the internals are beefed up also.
Personally, I did bolt-ons and will probably put a turbo on the replaces the stock turbo.
Tune+
St. Paul, MN
www.facebook.com
Adam
You can run an upgraded turbo on stock block, not an issue. However don't believe SOME of the things posted on the forums about pushing the stock block.
Tamadrummer88
Finicky
Austin, TX.
2015 Mustang EcoBoost Premium
After what I've been seeing and reading, I would just do an intercooler and tune for now. Then do big turbo upgrade later.
JSCOTT0812
Silverdale, WA
Justin
2021 GT
I want 600 HP safely on the stock block!!!! ha
BGolden
OKC
www.rip tuning.com
2015 EB Mustang & 2015 WRX STI
There will be direct bolt on turbos that will produce power levels to 500 in the very near future. I have already been pushing 53 lbs/per minute with the Cavalli and can produce more with what will be released next week, so if you purchase a down pipe and intercooler there will be a direct bolt on turbo that will mate to them and produce the power many are looking for.
evan546
Alright thanks
