Nuked
- Sep 15, 2015
- Morgantown, WV
- 2016 Triple Yellow GTPP w/Recaros
- Vehicle Showcase
- 1
These ECU's can handle fairly large fuel trims compared to older stuff. When you move the upstream O2 sensor further down, such as when you install LTH's, the Transport Delay is affected. There is a table inside the ECU that adjusts for this delay. You can leave it alone it will just adjust the fuel trims to accommodate, if you want it done right you adjust the Transport Delay so trims are as close as possible. Lund has all their tunes setup "LTH ready" meaning they probably use a middle ground Transport delay setting and turn off the O2 CEL. If you want to get down in the weeds you may see a small increase with VCT adjustment with LTH over manifolds. Specifically Exhaust cam adjustment for less retard.
