Trim Cover / Bumper Insert
1814GT350
Georgia
2018 GT350, 1971 GMC - 1988 GT - 1989 GT Pro Street - 1991 Vert - 1986 Coupe - 1987 Saleen 47
Anyone removed and replaced the Trim Cover (fr3z17e810ab) on the front bumper??
Can you replace without pulling the front fascia off?
Thanks !
MikeMM
VT
2021 GT500 on order
Thanks !
I have. Unfortunately there is no way to get it off without pulling the front bumper off the car because there is a small bolt in the back that holds it on and trust me when I say having the ability to push the clips from the back of the bumper is extremely helpful.
1814GT350
1814GT350
Georgia
Thanks! That’s what I was afraid of. I have a small chip, a rock or something nicked it.. driving me nuts.. I want to replace to make it perfect.
MikeMM
VT
2021 GT500 on order
I hit road kill and demolished mine... With 2 people and being careful it's a 4 hour project. I highly suggest if you have any intention of doing the HID upgrade or swapping out turn signals you do it all at once. You won't want to pull that bumper off a second time. Also check your splitter install and make sure it's Mounted correctly while you're at it. If you have any questions feel free to PM me and I'll be happy to walk you through it.
galaxy
St Louis
'17 GT350
Trying to visualize what trim cover is? I just pulled my whole front clip off to replace the lower grill and the air deflector behind it. Working alone, and pulling both front fender liners completely out, it took me maybe two hours. Not nearly as intimidating or dreadful job as I had built it up to be in my head. I’m the worlds worst for remembering to take how-to pics along the way!
MikeMM
VT
2021 GT500 on order
The hockey stick shaped things above the splitter. mine took 4 hours because I did the headlight conversion and the blinkers at the same time, but I'm sure had I not done that it would have taken far less time.
SiMuL
.wise selectah.
Houston, TX
Jesse
2015 Mustang GT CO PP
It only takes about 15-20 minutes to get the front bumper cover off. 30-40 minutes if you remove both front wheels. You don't have to remove the entire fender/wheel liner, just the tabs that are fastened to the bumper.
DO NOT forget about the two bolts that hold the far left/right tabs of the bumper to the fender.
If you have electric tools, the job goes quick.
1814GT350
1814GT350
Georgia
Thank you for the responses.
