3onthetree
- Jan 2, 2017
- Long Island, NY.
- Frank
- 2017 GT Man. W/PP
Hi everyone, I have a two part question I hope someone more knowlegable than me can help...I did a Torsen Diff drain/fill at 10k miles using the Ford Spec Motorcraft 75w-85 oil. I should have measured the level before draining, but did drain 1.5 L. Like the spec says and refilled same amount. The oil should be 9mm (.35in.) below the drain hole when filled, but I’m measuring about 12.5mm (.5”) so add more? Or leave as is?
My other concern is I now have a groan from the diff when making low speed sharp turns while accelerating. If I understand correctly, the factory fill contains XL-3 friction modifier regardless of whether the diff is LSD or Torsen, but the off the shelf fluid does not. The Torsen site says friction modifier is not needed, but can be added if the “groan is objectionable”
Anyone have experience with this?
Oh..and the old fluid did not smell like it contained modifier, which smells really bad.
Thanks, Frank
Thanks, Frank
